fuel pump relay wiring help
Old Aug 31, 2013 | 05:05 PM
crash's Avatar
Default fuel pump relay wiring help
posed this over in engine management but figured you guys may know too
Ok so I am rewiring my race car and I have a new fuse box that has built in relay spots.
I planned on using the ems to trigger the fuel pump relay and am having some issues.
I have the relay wired as such
30 ignition
85 ecu trigger A15
86 Kill Switch power
87 to pump
Am I doing this right?
Old Aug 31, 2013 | 09:03 PM
dsddcd's Avatar
Based on what I can tell this may be a better configuration
Power to Pump
30 Kill Switch / Main Power Disconnect
87 or 87A to pump
Relay Coil
85 ECU trigger A15
86 Ground
Thought you were selling your car?
Old Sep 1, 2013 | 03:47 AM
Unbr3akable's Avatar
Is the ECU trigger a high or low when active? i.e. does it provide power or ground to the relay switch?
If the ECU trigger provides a ground when active, "Kill Switch Power" should be providing power (i.e. battery voltage).
If the ECU trigger provides power when active, "Kill Switch Power" should be providing a ground.
Hope this helps,
Caleb
Old Sep 1, 2013 | 08:32 PM
crash's Avatar
I got it working.
30 fuse power
86 a15 ecu low side
85 switched power
87 power out
I dont know what I had going on but its up and running
Now I just have to figure out the IQ3 settings lol
[attachment=45005:2013-09-01 20.07.07.jpg]
[attachment=45006:2013-09-01 17.15.37.jpg]
[attachment=45007:2013-08-28 13.17.23.jpg]
Attached Thumbnails fuel pump relay wiring help-2013-09-01-20.07.07.jpg   fuel pump relay wiring help-2013-09-01-17.15.37.jpg   fuel pump relay wiring help-2013-08-28-13.17.23.jpg
mugen888
Sep 9, 2006 02:56 AM
Fantasi07
Apr 24, 2005 12:42 PM
krazylune
Oct 15, 2003 01:54 PM
bguernsey
Feb 15, 2001 07:50 PM
