Gendron front sway bar
Thanks for the info Marc!
I installed a Saner bar a few months ago and went through the end link update. The end links cost as much as the used bar. Looks like I will be going through it all over again.
Just found out the Gendron I'm looking at is the updated one.
after putting on my coil overs i am running into the clearance issue now as well. maybe if i dial back the camber a little it might give me more space? i installed the J's camber kit and have the camber settings pushed to max negative.
Dialing back camber will make the shock closer as your pulling the bottom control arms inwards towards the endlink.
-To the OP - does your have the updated captive end links? my bar has the updated arms but still have the bolt and nut fasteners. i emailed Small fortune racing to see if i can acquire the updated links. if not im sure i can make my own. i just have to measure the adjustment hole diameter to make sure i get the proper size stud. i am also trying to use the 3rd hole closest to soft.
i guess i can always start out at the second setting. and change it out later when i get the updated links.
totally forgot i had an extra set of shorter shank end links. i got the bar on but im still concerned that there isnt enough room from the end link and shock. i got a hold of Bill and i will try and purchase the updated links. i looked through mcmaster carr and it seems the end links they have that would be the right diameter (i think) 3/8 or 5/16 shanks will be too short.
), my S is stored for the winter so I have time to figure things out.
