Harness install questions
I'm installing harness's Currently using pci brackets. On the passenger side. mounting space is very limited to install the sub belts, also the rear diagonal bar on the hard dog bar is very close to Interfering with the shoulder strap.
Any suggestions or pictures to help give me some pointers on the easiest way to do this side?
It's okay if the left shoulder strap contacts the diag bar. At least mine did and we had no issues there. I drilled holes in the floor for my sub strap eye bolts. If you can post pics, that would be helpful.
The mounting hardware that comes with the harnesses might not fit well under the seat mount. I have PCI seat mounts and ordered a set of the B59 brackets from Schroth for the sub belts: https://www.schrothracing.com/products/bolt-in-brackets
On the driver side i was able to just drill holes in the floor and welded some backing plates to the bottom for good measure, but that damn exhaust tunnel hump makes the passenger side a real pain.
any pictures of how those brackets actually work? I see it says that its a pinch style? Im unfamiliar with that.
Ordered them from HMS motorsport along with the 2-bar slides for wrapping the belts, bolts, and sleeves.
SR B24.15.13 NC - B24 brackets
SR S65 - Sleeve for 7/16 bolt
SR LV4 - 2-bar slide
SR SG10 - 7/16" bolts
In fact, if I recall correctly I ordered four of each (for driver's and passenger's sides) but then found I only needed them on the passenger's side like you. I'll have to double check, but I may still have two of each.
Actually, looking back I recall that I had planned to get the pinch brackets, but instead opted for the B24 - cheaper and same result that it's lower profile that the standard hardware. If you click the installation instructions here you can see a picture of the B24 with wrap. It's similar to how you wrap the standard hardware. https://www.schroth.com/en/segments/...tructions.html
Sorry, took a look and can't find 'em. I've got a bunch of the spring-loaded ones and eye bolts and such, but no B24s. Should be straightforward to order that list online though^^
Jibarito
Aug 13, 2017 04:51 AM
geras003
May 11, 2011 11:42 AM
ITRbroham
Jun 9, 2004 07:55 PM
