harness mounting?
Old Jun 10, 2003 | 03:15 PM
minboost's Avatar
Default harness mounting?
considering getting sparco rev seat. need harnesses. just a 4 point.
where r u guys mounting your harness WITHOUT adding a roll bar or cage and NOT mounting it to the floor?
I don't mind gutting my car from the seats back to expose the factory metal roll hoops, if necessary. Just need some ideas...
Old Jun 10, 2003 | 03:31 PM
Ludedude's Avatar
Administrator
Any type of harness without a rollbar or cage is highly discouraged. You'll lose your head in a rollover. The stock belts are all you should be using with the factory roll hoops. Really.
That being said, I'm assuming you're doing this for show purposes; PM Rick Hesel as he has just finished doing the same thing albeit with a 6 point harness.
Old Jun 10, 2003 | 03:54 PM
krazik's Avatar
Administrator
Talk to aaron bitterman (aaron@speedventures.net) he has a kit that will allow you to mount a harness w/o an aftermarket roll bar.
Old Jun 10, 2003 | 09:03 PM
minboost's Avatar
no this is for the track. car show? ahahahahaahaha
minboost's Avatar
p.s. i am gonna cage my car up but not until i buy another car...
Old Jun 10, 2003 | 09:30 PM
Ludedude's Avatar
Administrator
Laugh away. Don't use a racing harness with the stock roll hoops. You will do more damage to yourself in the event of an accident. Do a search, there's been a few threads discussing this issue and detailing why it's a bad idea.
Old Jun 11, 2003 | 07:08 AM
krazik's Avatar
Administrator
Ludedude is right about a harness w/ stock roll hoops. Just be warned that if you roll and have stock hoop w/ a harness, you've pretty much guaranteed to hurt yourself significantly (neck) or possibly kill yourself.
-Ry
Old Jun 12, 2003 | 12:29 PM
MSRS2K's Avatar
Does anyone have any evidence for believing that it's more dangerous to have a harness with the stock roll hoops, or is this all pure conjecture?
Assuming that a seat and rails (sparco or other) will lower the seating position 2-3 inches and drop my helmet below the roll hoops and windshield frame, I gotta believe I'm far safer in a rollover, or any accident, with seat/harness than with the stock seat/belts. I'm 5'11". (My conjecture is better than yours)
- Michael
Old Jun 12, 2003 | 12:48 PM
jerrypeterson's Avatar
[QUOTE]Originally posted by MSRS2K
[B]Does anyone have any evidence for believing that it's more dangerous to have a harness with the stock roll hoops, or is this all pure conjecture?
Old Jun 12, 2003 | 01:06 PM
krazik's Avatar
Administrator
its not exactly something that needs a roll over to prove. Sit in the seat and see. Is your head below the roll hoops? Then run a peice of wood between the top of the window frame and the roll hoop. Are you still under it? If you aren't under it w/ some room to spare, its your head thats gonna be holding the car up when you're upside down.
Its just something to consider. You can chose to ignore it, I did for otc as I had no choice but to run the stock bars to fit the hard top. Its a calculated risk, but -if- you go shiney side down, you're gonna get hurt.
