Harness Mounting question
I've learned a heck of a lot on properly mounting harnesses as I've read lots of posts from various forums trying to put all the info together.
My questions mainly comes about in regards to the shoulder harnesses. Everything I read says harnesses need to be mounted at horizontal or no more than 10-15 degrees below. Much lower and you risk the harnesses pulling down and compressing your spine in an accident, and higher than horizontal and they might lift up and not keep you as secure as they should.
My problem is that I'm probably on the larger side of most s2000 owners. 6' tall, 220lbs, 36 waist. Finding a proper seat doesn't come as easy. I'm on S2000 #3 and my seat of choice has always been the Recaro Pole Position. Fits in the S2000 perfectly and I find it pretty darn comfortable. The lower driving position is a huge perk. Everyone knows one of the biggest problems with the seat is the harness holes are on the low side. They look to be about 1.5" too low for me. Thankfully I don't have a super long torso or it would be much worse.
On top of that the car sees more street time than anything else so this is not some stripped out race car or dedicated track car. Car will see mostly autocross but the goal is to do 1 or 2 HPDE events a year.
What is my risk if I keep the Pole Position and say run the harnesses at a slight positive angle respective to the seat? I'm talking 3-5 degrees. Might allow for a slight bit of lifting but due to the low harness holes that would normally pull down on my shoulders keep me OK? I realize this is pretty much the wrong way to go around it but I ask none the less. I'm looking at other options for better seats but I'm not pulling the trigger without sitting in something first and taking enough measurements to know it'll fit in the S2000.
Or am I better off just slapping in a rollbar, putting a pair of buckets in and just using OEM seat belts?
well once you get the roll bar in then you can contemplate the harness. even then you have to either have a high harness bar or get bulkhead replacement as that will block the harness. there are more seat options for you. my new favorite is a cobra suzuka.
I won't fit in a regular size Suzuka and I don't think the wide version will fit in the s2000.
I'm also aware of how the factory bulkhead gets in the way of the lowered harness bar. Bulkhead replacement will be purchased as well.
And I'm not going out on track anytime soon. I'm more in the planning stage than anything else.
I texted you. I was just referring to your first sentence. I found the Schroth instruction PDF really helpful, specific and reliable (seeing how they are FIA approved and both Schroth and FIA do so much testing and have so much data to pull from).
This picture shows you kind of what I'm looking at. Even happens to be the same seat.
The harness bar is basically at the correct level for my shoulders but the harness holes in the seat are not so when strapped in the harnesses are going to again the top of the harness guide not the bottom. That picture is even more extreme than what I'd be thinking. Imagine that same pic but with that harness bar an inch or two lower to the point where it's almost horizontal with the harness holes in the seat but just slightly above.
How does that affect their operation? I don't see how they can compress me when they are mounted higher or they'll have a much harder time doing it. Just trying to think outside the box a little.
