Harness question
The aftermarket seat i bought doesn't have a hole for the 5th and 6th point of the harness to go straight down to the floor. Is it ok to bolt it to the floor behind the seat and have them come up through where the seat reclines at and sit on the harness to fasten it? I hope this makes sense thanks!
http://forums.corvetteforum.com/c6-z06-dis...mendations.html
this is a set of brackets made for this type of installation:
http://www.bkauto.com/corvette/r9115.php
so basically you sit down on the straps, and then pull up the locking part up between your legs to hook into the cam.
i use this, which only requires 4 attachment points but is a 6-point and keeps you from submarining:
http://www.teamtechmotorsports.com/racingh...s/jetpilot.html
B) Always follow the instructions that came with the harness EXACTLY.
Originally Posted by dnedwick,Oct 15 2009, 07:45 PM
Well someone i know who races said that should be ok. Anyone else have input? Would it be safer to just run a 4pt?... What are my options in an aftermarket seat with no hole for a sub strap??
