Headlight plug diy.
Hi all. I'm posting up to share a few images that might help some other folks.
I did this in order to drop a little weight and because I happened to have a set of beat up OEM headlights I had disassembled so I could sell off the hid housings.
These images should help explain how the lenses/plugs are situated. The key is that there is a tab w/ hole on the fender stamping hiding away on the underside. I have no idea what that tab was even for.
Aluminum strips 90° bends and adjustment slots are all that's needed to hold the bottom side of the light at two locations.
I'm struggling to see the benefit.
Aren't the headlamps combined, maybe 10lbs? So, gutting them is a insignificant amount of weight savings.
However, I can see where having the headlamp lens cut to be used as ducting. That would be far more beneficial. Are the lens glass or plastic?
mcola
Jun 7, 2005 07:22 PM
