Heat induced Transmission Problem
My transmission gets more difficult to downshift as the day goes on at a track day. It does not grind, it locks me out.
see video:
[media]http://www.youtube.com/watch?v=jDGZaO9vMpc&feature=plcp&context=C4b13d4bV DvjVQa1PpcFOQTbcD-ORPS_xEPPDOYVBT-m9u1A6rke0%3D[/media]
Has anyone had success with a different transmission fluid? There is GM MF formula, and also Pennzoil Synchromesh MTF. (Are they the same?)
My S is a high mileage car and I currently use Honda MTF. It shifts OK in normal street driving (but not as good as when new).
Thanks in advance
Jim
see video:
Thanks in advance
Jim
I use Amsoil MTF and change every 3-4 events.
Since your car is hight mile, you could check your tranny mount and shift lever collar.
I don't think that's causing lock your shifter out by heat but, it'll affect your shift feel for sure.
just wondering, but have you tried changing out your clutch fluid? A member on here recently had the exact same problems and all was solved via clutch fluid change. Its a very easy 5 minute job, use a turkey baster to suck out all the old fluid, replace with new fluid, cap, pump clutch, and repeat till clean.
