Heat induced Transmission Problem
Old Mar 22, 2012 | 02:58 PM
jelanier's Avatar
Originally Posted by Carbon Blue
just wondering, but have you tried changing out your clutch fluid? A member on here recently had the exact same problems and all was solved via clutch fluid change. Its a very easy 5 minute job, use a turkey baster to suck out all the old fluid, replace with new fluid, cap, pump clutch, and repeat till clean.
Clutch fluid was changed about 2 months ago. I replaced tranny fluid with GM MF recently. I ran it for 1 week, drained it and put in Pennzoil Synchromesh. The GM had a gummy feel. The Pennzoil is working fine for street driving. I will see how it does on the track. I am practicing heel and toe double clutching for just in case
Oh, quick question..
If I am at a stop with clutch in and in neutral. Then if I move into first gear and the RPMs are unchanged..then clutch is OK right?
Jim
Old Mar 22, 2012 | 03:13 PM
rrounds's Avatar
I know some people use MT90 in the transmission.
https://www.s2ki.com/s2000/topic/931...#entry21437347
https://www.s2ki.com/s2000/topic/929...y-experiences/
ROD
jelanier
Mar 13, 2012 11:29 PM
ETKMS
Apr 18, 2011 02:57 PM
Vitt
Nov 7, 2006 05:15 PM
Jasonoff
May 26, 2006 04:36 PM
jwkim
Sep 30, 2004 09:47 PM
