heel toe?
Originally posted by CMiS2K
I'd like to, traveling with out away to take the tires with me is the problem that I have. I am not going to drive 4 hours on race tires.
SphinkterMC drove from LA to SF ran sears for 2 days and drove home on a set of hooisers.
He said they didn't wear that much from freeway miles.
No steel belts makes them a little scary, but just case and point
CMiS2K,
Don't sweat it. I rarely if ever HT and I'm still faster at the track than any other S2k around here. Of coarse everyone will tell you its all car and not the driver.
But seriously, HT will improve your times once you learn to use it effectively. That is likely a big part of the reason that JZR is faster than me in my own car at the streets of willow springs. Its a tight technical track with a lot of 3 2 down shifts into tight turns. That and he has a lot more experience than me on tight technical tracks and autocross. The point is you can be very very fast with out HT but chances are you can be faster still when using it.
Originally posted by krazik I am pretty sure I took 2nd fastest over all
My first cone dodging event (PCA) I took first overall with the chick car
btw: I never said you can't be fast w/o h/t, but you can always be faster than you were if you h/t.
We all know everything you do out there is about being smooth. If you're not -as- smooth you're going going to be -as- fast.
