heel toe?
Old Sep 25, 2003 | 10:13 PM
  #71
Strike's Avatar
Originally posted by Ludedude
Dave, come on out to Pahrump and I'll teach you how to heel and toe
J.P.,
Better watch what you say. You're with the big boys now
Old Sep 25, 2003 | 10:16 PM
  #72
Ludedude's Avatar
Administrator
[QUOTE]Originally posted by Strike
Old Sep 25, 2003 | 10:26 PM
  #73
Strike's Avatar
[QUOTE]Originally posted by Ludedude
Old Sep 25, 2003 | 10:28 PM
  #74
krazik's Avatar
Administrator
just make sure strike isn't too close behind you, he might rearend you.
and watch out for strikes fluid leaking issues. He needs depends.
Old Sep 25, 2003 | 10:41 PM
  #75
Strike's Avatar
[QUOTE]Originally posted by krazik
Old Sep 25, 2003 | 10:42 PM
  #76
krazik's Avatar
Administrator
yeah, but I had to hear -everyone- whine about it
Old Sep 25, 2003 | 11:49 PM
  #77
Ludedude's Avatar
Administrator
Old Sep 26, 2003 | 03:33 PM
  #78
CMiS2K's Avatar
[QUOTE]Originally posted by CMiS2K
I have 300 whp with my SC S. Vtec is lowered to 5300. My braking, clutching and shifting techniques maybe different than conventional means that you all are use to doing. I am driving 80-85% of the limit I am still learning how to push the car to the limits with, powerslot rotors, hawk pads, motul fluid, ss brake lines, jic coil overs, x-brace, 30mm sway bar, toda flywheel, ACT PP, ricks pulley's, stb, upper and lower rear braces, and Vortech SC. My car is never the same at any 2 events due to mods that I continue to add or tweak. Oh and I run on 17/225/45 and 17/255/40 V700's wrapped around ASA FR1's.
Old Sep 26, 2003 | 04:19 PM
  #79
jguerdat's Avatar
If I might interject, it may be time to STOP changing things. You don't know what you're doing right and wrong if there's not a stable platform from which to compare.
Old Sep 26, 2003 | 04:44 PM
  #80
CMiS2K's Avatar
Maybe or maybe not?
As I can see your one of those BS guys, leave the car 'stock'.
Gut instinct with hours of research and time spent in the car lead me to the changes that I have made. I have want I want out of the car currently.
How do you know what my car experience or expertise is, if any?
If there is an event available to run, I am there. I have had a stable plat form to work with for over a year. I have left the car the same for at least 2 events, sometimes. I accelerate change when I am ready or when I want to with factual justifiable reason, drawn from questions and answers which has brought me to the conclusion of change.
Does any race car team ever leave the car the same for each & every event? Or do they tweak and change things for each track based on elevation, weather conditions, surface condition or physical make up, more horse power, less horse power, + or - tire pressure, stiffer or softer suspension, more or less understeer, etc. If you don't change and tweak things, you probably experience a plateau and don't experience anything different and then wonder why?
