Help, Auto-X classes
Old May 5, 2001 | 01:16 PM
krazik's Avatar
Administrator
ok, a "stock" s2k is in AS,
a sightly modded on is in CSP.
What about supercharged ones?
Where are the lines drawn?
Old May 5, 2001 | 02:25 PM
Schatten's Avatar
would it be pushed into a mod class?
Wesmaster drove an autox in Houston with his SC'ed S2k a few weeks ago - it wasn't held by the Houston region SCCA - to my knowledge. I posted a question asking who hosted it and what class he was placed in, but I dont think he looked back to respond.
Old May 5, 2001 | 02:58 PM
CG's Avatar
CG
It would go into a mod class. My guess would be E-mod.
Are slightly modded cars going into CSP or ASP?
Old May 5, 2001 | 03:00 PM
krazik's Avatar
Administrator
I am told CSP.. because we are less than 2.0 litre
krazik's Avatar
Administrator
where is the line drawn between xSP and xP?
Old May 5, 2001 | 03:36 PM
Dum Dum Head's Avatar
okay, I think I got it:
http://www.moutons.org/sccasolo/Rules/index.html
If you read the part from the Street Prepared engine category, it states
"Turbochargers may not be added, changed or modified."
Guess that means, adding a super/turbocharger is going too far... There are some other interesting things in there too that are worth reading about. Most bolt-ons would keep us in street prepared though. Although it says
"Air ducts may be fitted to the brakes, provided that they extend in a forward direction only, and that no changes are made in the body/structure for their use."
Does that mean we can't cut out fake brake ducts in the front bumper to use as real brake ducts? Not that this would make any difference in an auto-x anyways, but this is my next mod that I'm planning.
So, that means a supercharged S2000 would be in D Mod, since our cars are over 1000lbs with a displacement under 2000cc. Imagine would bad our cars would be killed in that class. [on edit] actually, I know of a supercharged Mustang that runs in C-Prepared, so I think a supercharged S2000 would be alright in prepared, but I don't know which class though.
[Edited by Dum Dum Head on 05-05-2001 at 04:42 PM]
Old May 5, 2001 | 06:41 PM
j2k's Avatar
j2k
A Street Prepared S2000 would be in CSP... though its not elligible to compete in any National level event in any SP class yet, because it has not been specifically classed.
A superercharger would bump you into E Mod... true if you have less than 2.0 liters of motor you can go into DM, but super/turbocharging counts as 1.4 times displacement... so into EM you go.
Cutting holes for brake ducts in the front facia also bumps you into Mod... not prepared. In Prepared, you can remove the headlights and use those holes for brake ducts, but you cant cut any new ones. You can also add a front spoiler below the front grill of the car and you're allowed to mount brake ducts to that as well.
Clear as mud eh?
Were you to build a Prepared S2000, you'd be in AP.
Originally posted by Dum Dum Head
... actually, I know of a supercharged Mustang that runs in C-Prepared, so I think a supercharged S2000 would be alright in prepared, but I don't know which class though.
Actually no. Its not legal to add a supercharger in Prepared. Probably the only reason why this guy is running in CP is because he's only doing it locally and nobody cares enough to protest him. He most likely wouldnt get away with it at a national level event.
hope that helps.
-jason keeney
Old May 5, 2001 | 07:00 PM
wow. thanks jason. that's exactly what we needed. =)
Old May 5, 2001 | 08:52 PM
krazik's Avatar
Administrator
j2k,
You don't have to cut the bumper to put them in, you only remove a couple screws to remove the plasic piece.
I still don't understand what the diff between Mod and Prep is tho.
Old May 5, 2001 | 09:13 PM
cdelena's Avatar
There are no screws. The covers over the fake ducts are a molded part of the bumper.. they must be cut out.
