Honda Challenge s2000 to NASA ST4...
Old May 8, 2017 | 06:40 AM
DHonovich's Avatar
Default Honda Challenge s2000 to NASA ST4...
So I race a 2002 s2000 in the NorthEast Honda Challenge H1 series. I want to dabble in some ST4 but I am not sure if anyone else has made this jump. I was thinking of trying to stuff the 245/40/17 R7 hoosiers and giving it a try.
Power is 205whp
Weight is 2650ish
For ST4 I am sitting at 13.9 ratio instead of the 12 that I can be if I run R7s. This means I got to shed some serious weight (not easy at this point) or find 56whp
EXTERIOR
Arospeed tow hooks
OEM style front lip spoiler
APR GTC-200 trunk spoiler
APR 2.5" riserOEM style front lip spoiler
RSG Amuse style hardtop
RSG front hardtop brackets
RSG 2 piece rear hardtop brackets
INTERIOR
Torque Solutions tear drop shift knob
SPA 4L Alloy Electrical Multi-Flo AFFF system with extra hose
Innovate MTX D oil pressure and temperature gauge
AEM Infinity with wideband from SoS
Evans Tune
Ultrashield Rally Sport Halo seat 16"
Scroth profi II-6 hans
PCI Multi-Adjust Race Spec seat mount
AutoVation heel guard (grid, matte, no perimeter)
AutoVation pedal set (aluminum lightweight, grid, no perimeter, no grip pattern on accelerator and dead pedal, all through holes, matte
Race Keeper HDX2 two camera system with OBDII adaptor
Momo tuner steering wheelPunisher horn button
NRG quick release 2.5
NRG short hub SRK-131H
DRIVETRAIN
SakeBomb Oil Cooler
UPR Honda S2000 Dual Catch Can
PuddyMod egr block off plate
Track Forged baffled oil pan
Berk header back exhaust with gutted catalytic converter
AEM cold air intake
Innovative billet motor mounts 95a
Innovative billet differential mounts 95a
Innovative steel transmission mount 95a
Radium FST
ACT H021 HD PP
CHASSIS & SUSPENSION & BRAKES
Anze Penske 8300-DA 2 way remote
Karcepts s2000 front (0.250) and rear sway bars
Megan front RCA
Ballade Sports spherical bushing kit
Ballade Sports steering rack bushing kit
Manzo subrame collar kit
Custom brake ducts
Stoptech ST40 front brakes
Carbotech XP12/10 or 10/8 brake pads
ARP wheel studs
Kosei K8r 17x9 +60 x4
Toyo RR 255/40/17
TSW nurburgring 17x9 +63 x8
Toyo RA1 255/40/17
CIP Motorsports rollcage
I/O port seat brace
Old May 8, 2017 | 09:43 AM
King Tut's Avatar
That would be the correct answer. Adjust weight if possible and throw on the 245 Hoosier R7s. You probably have enough ratio to run the A7s, but I'm not sure you will want to do that even in a sprint race format although the fast ST2/ST3 cars used to do it on Hoosier A6s.
Old May 8, 2017 | 09:54 AM
RedCelica's Avatar
I'd think you'd need 10" wheels to run 245 hoosiers (in a good way ). See if 949 racing is going to make their 17x10 +72s again (they have +52s right now, which might require too much fender modification)?
If you do go with another set of wheels...I want your Kosei's
Old May 8, 2017 | 10:55 AM
DHonovich's Avatar
I weigh 2688 with me (175lbs) and passenger seat installed so I don't know how much more I can go without getting really crazy cutting little tabs off that are left. I do want to go k24 if I leave HC.
DHonovich's Avatar
I can't wait till 5/31 when I can order more from TireRack. I will be getting at least another 3 sets. Best wheels ever on s2000.
Old May 8, 2017 | 04:35 PM
BlueBarchetta's Avatar
Also double check the aero rules. I think an OEM style lip can qualify as the allowed splitter, but if your hard top is not an exact OEM copy, It's not legal in ST4
Old May 8, 2017 | 05:25 PM
DHonovich's Avatar
I missed that but you are correct
2) Modification of the OEM roof line and/or removal of the front windshield/frame is permitted, but will be assessed via a Modification Factor in the “Adjusted Weight/Power Ratio”.
-0.3 is the factor.
Old May 9, 2017 | 04:52 AM
f20kills's Avatar
-0.3 is the factor.
Correct. Its legal. You take points for non OEM shape hard top and you also take 1 point for A7s (TT4/ST4).
OEM AP1 lip is legal. Throw on a splitter as well up to 4"
Old May 9, 2017 | 05:31 AM
DHonovich's Avatar
The splitter has made me slower on all times that I have tested it but I do like having the lip on the car. I may have to try the A7 too then.
Do you guys think the 245 hoosiers will fit with the wheel offset I have?
Old May 9, 2017 | 05:36 AM
f20kills's Avatar
I should clarify, you'll take Negative 1 point for A7. But if youre not close to 12:1 its not an issue. 245 Hoosiers are just slighler wider than a typical 255 (10.2) IIRC. 245 Hoosier is 10.3
