How do these Alignment specs look
This is what I was told I should run, but wanted to get a bit more feedback before I have the alignment done on Tuesday....
front -2.2 camber, 6.25 caster, 0 toe:
Rear -2.5 camber, 1/16 toe in:
This was not for my exact set up but more of a baseline.
My setup:
225/45/17 Direzza Star Specs Front
255/40/17 Direzza Star Specs Rear
Prodrive CG-05 +48 fronts, +50 Rears
On Buddy Club Race Spec Coils not dumped but low. Set pretty firm up front medium in the rear.
No other suspension mods but have the rear of the interior gutted and most of the trunk, and a Hard Dog Roll Bar with Pole Positions and harnesses...
This is for HPDE at Portland International Raceway (For Now) and the car is almost dedicated track car.
If I need to provide any more info please let me know! Thanks!
My setup:
Another question, still hoping to get some advice on the alignment, but have the chance to pick up some R6 hoosiers for cheap... But they are all 245/40/17. What do you guys think about running these size tires with my set up?? Front rim is 8" and rear is 8.5"
Thanks!
Thanks!
Those alignment specs look good to me.
I would say anything 8.5" and over will work a 255.. I ran a 235 RE01R on a stock 7.5" front that worked pretty good
A "cheap" hoosier would probably have seen its best days and might only give you 1 event and you have to get them mounted.
