Sponsored by: Sake Bomb
Alignment spec?
Old Feb 20, 2010 | 12:42 PM
Lucifer's Avatar
Default Alignment spec?
Hi, guys I need some advice for this setup please.
HKS coilovers, 17x9 +40, 245/40/17 all around and no sway bars (yet).
I was thinking about this spec. Is this good? And how you set your damper for street and track? likes how many clicks as a sugguest.
Front:
Camber: -2.5 deg.
Caster : 6 deg
Toe: factory
Rear:
Camber: -3.5 deg.
Toe: factory
Old Feb 20, 2010 | 07:28 PM
driftintherain's Avatar
I can't help you with the question you asked, but how do you like your coilover?
Old Feb 20, 2010 | 08:04 PM
JDMQuip's Avatar
Front:
Camber: -2.5 deg.
Caster : 6 deg
Toe: factory
Rear:
Camber: -3.5 deg.
Toe: factory
I have similar specs on my 17x9 +45 all around with 245/40/17's.
I have -2.5 up front and -3 in the rear. Toe is at 0 and I'm dropped pretty aggressively.
I think you will be OK with -3 or even -2.5 camber in the rear.
Old Feb 22, 2010 | 04:24 PM
Lucifer's Avatar
-3 in the rear sounds good to me for the tires life. I just want to have a proper align and make sure that I won't rub.
Thanks.
Old Feb 24, 2010 | 09:40 AM
GT Motoring's Avatar
Former Sponsor
We run -3 to -3.5 in front and -2.75 to -3.5 in the rear generally.
Old Feb 26, 2010 | 12:20 AM
Lucifer's Avatar
Thanks for the info. I'm getting my alignment done tomorrow.
H22toF20
Mar 16, 2014 10:30 AM
mrcbr600
Aug 5, 2010 12:48 PM
Nu4mulaRedd
Nov 2, 2009 04:02 PM
mcopley
Jun 3, 2009 04:28 AM
