How Do You Left Foot Brake an S2000?
Old Aug 27, 2004 | 09:38 PM
David NJ's Avatar
Default How Do You Left Foot Brake an S2000?
Pedal is far to the right. And it really seems you need the clutch to change gears in either direction.
My Lotus Elan ('68 S4) had a tight pedal area. However you once rolling you could shift all day without the clutch.
Old Aug 27, 2004 | 09:48 PM
payneinthe's Avatar
I don't know -- have never succeeded despite lots of tries. I really just wanted to thank you for spelling "brake" correctly. A rare skill indeed these days.
Old Aug 27, 2004 | 10:00 PM
1.8t's Avatar
I thought left foot braking was for only for fwd cars to help rotate/tighten the line without having to let off the gas. Are there any benefits to the already oversteer prone S2k w/ left foot braking??
Old Aug 27, 2004 | 10:32 PM
rlaifatt's Avatar
Very beneficial in a couple of ways at least. It allows you to better balance the car in a corner/sweeper by being able to vary both the gas and brake simultaneously and seamlessly; allows much quicker and smoother transition from brake to gas if no shift is required, particularly if you are left-foot trail braking; allows you to rotate the car on braking and transition to gas with more control. Often useful also after the downshift in longer corners. Overall, better balance --> smoother --> faster. You really have to lift your leg and move it to the right to get over the clutch and to get your foot on the pedal, so a bit awkward at first. I'm in the learning stages, and Ive already seen the benefits. I wear narrow racing shoes, and I think it would be more difficult with wide shoes.
Just thought of this. If you aren't in a race seat and harness it might be much more difficult to LF-brake in the S, at least for right-hand corners, since I recall having to brace the left knee against the door to stay in the stock seat.
Old Aug 27, 2004 | 11:32 PM
Ludedude's Avatar
Administrator
Indeed. My bruises from WSIR just went away. I can't wait until next week
Old Aug 27, 2004 | 11:50 PM
RACER's Avatar
Left foot braking is useless if you have to shift gears. I can't see myself using my left foot to trail brake, then use my right foot to brake so I can go down a gear, then uses my left foot again and so on. We all know this car will not shift without the use of the clutch. I am pretty set on right foot braking.
Old Aug 28, 2004 | 04:33 AM
Windscreen's Avatar
For autocrossing, I LFB whenever a 2-1 downshift is not required. For those corners, I use my right foot and left on the clutch. It certainly took a while to get good at it. I practiced for a year in my automatic equipped truck before I started in the S2k. Initially, I'd get confused feet sometimes and jerk the car forward when I meant to hit the clutch on an upshift.
I LFB when ever possible on the street, just to stay in practice and to keep my feet trained and ready to actuate the clutch or brake as needed.
Steve
Old Aug 28, 2004 | 06:03 AM
rlaifatt's Avatar
[QUOTE=Windscreen,Aug 28 2004, 04:33 AM] For autocrossing, I LFB whenever a 2-1 downshift is not required.
Old Aug 28, 2004 | 06:54 AM
cdelena's Avatar
I have found one place where I can use a touch of brake, on a long high speed sweeper. One of the track old timers pointed out that it is a way to adjust in this long corner when you might be a bit hot but don't want to upset balance by getting off and on the throttle. I am not coordinated enough to use the technique many places but it does work in this turn because I have time and am prepared.
Old Aug 29, 2004 | 09:52 AM
The Reverend's Avatar
That's what I've been doing. It's easiest barefoot, but I practice in my race shoes sometimes also. I'm pretty smooth with it on the street now, but I have yet to really try it on the track in my car.
