Impact of 100lb weight reduction in a 3100lb car in a time attack setting?
I am wondering if anyone has done testing here to measure the impact of adding or removing 100lbs in ultimate lap time in a higher speed track environment. I'm a racer and mechanical engineer by education, understand physics, of course removing the weight for all the obvious reasons will make the car quicker. But can anyone here offer any real world data of their own in this Chassis Weight Range and Speed Range? Assume a typical 15 corner roadcourse, with 3 long acceleration zones, 5 corners with cornering speeds in the 70-80mph or so range, lots of elevation change, a high speed banked 100+ mph corner, and 115mph braking zone down to 45mph or so. (My specific example is a Showroom Stock 1994 BMW 325 I, on R6's, at New Hampshire International Speedway Road Course in case you are curious.)
So has anyone tested the impact on their lap time in back to back sessions by adding or removing signficant amounts of weight? What was the result?
I have a lot of experience as to the impact of weight in autocross speeds/environment. In one example, another 200lb passenger in an NA miata was around 2 seconds, with 55mph max cornering speeds. But of course, the impact on weight in cornering speeds goes up as the cornering speed goes up (it's physics). F1 cars are on the order of 5-7 seconds slower in full fuel trim (an 800 hp car in a 1200lbs chassis) with tremendously high cornering speeds. I have personally logged lap times at a local go kart track, and with almost freakish clarity of results, adding 10lbs to a 6hp indoor go kart was worth just over 1 tenth of a second on a 36 second track, with ~25-30mph cornering speeds.
All data points in different environments. So what say you? Can anyone share their data for ultimate lap time impact by removing around 100lbs in a ~3000lb car in a typical road course level of speed environment?
My thanks in advance.
Very Best,
Nick
Very Best,
Nick
I suspect the difference between 3100 and 3000 pounds is less than the lap to lap variation of a non-pro driver, i.e. impossible to detect under most any circumstances.
I suppose if you had a enough laps under similar weather conditions, not limited by traffic and ignore the effects of tire wear and changing fuel load... at both weights, perhaps then if there is a difference, it may be due to the weight savings.
weight reduction is weight reduction. It is always going to make a difference, whether or not you notice is a different story. If you are not extremely comfortable with oversteer, I would not recommend removing from the rear of the vehicle.
Thanks,
Nick
Personally, I'm around ~3.5% faster (lap times) without a 200 lb. passenger (~ 2850 to 2650 lbs.) at VIR. Same conditions, very consistent, and recorded with a DL1 data logger. You gain time everywhere. As Colin Chapman said, "Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere."
