View Poll Results: To install and drive 30 miles or no?
Voters: 23. You may not vote on this poll
j's racing s1 camber joint
same as stock except ~10mm+ longer? i don't have a pitch gauge or calipers to measure.
i have the bolts and rca plates from my L1 that i'll sell if you need them. i didn't do my research and only realized later that the rca plates are recommended when you lower the car 40mm or more.
-dan
-dan
-dan
-dan
yup the ball joint is a easy one. When you take off the wheel and look at how simple it really is you will laugh.
as daverx mentioned, just put on an all season and drive cautiously to the alignment shop.
You could always pull out the strings and level to get the tire in question close to spec alignment and then just drive to the alignment shop on that.
C
C
Originally Posted by ghostshadow,Jun 29 2010, 12:31 PM
these are j's guidelines..
S1 - Extra 2 degree adjustment for a S2000 with a stock height up to 40mm down
L1 - Extra 2 degree adjustment for a S2000 with more than 40mm down (can be used as S1 without the adj plate)
there's great discussion in these forums with regard to roll centers..
If the stock adjustment has a range of 0-2*, then adding the S1 moves the range to 2-4*?
If someone can get me hardpoints I can put it in ADAMS\Car and get any kinematic stuff you want.
i didn't see any rc discussion here?
i've just searched 'roll center' and found some good nuggets of info on/including rc's buried in a lot of posts. i recall one person posting that they've tried with and without the plates and they couldn't perceive a noticeable improvement.. subjective but interesting
This proved invaluable to me in removing my balljoints: http://www.honda-tech.com/showthread.php?t...move+ball+joint
Instead of the ratchet, I used an 18mm craftsman wrench.
