J's S1 Troubleshooting Help
Old Mar 12, 2014 | 06:41 PM
gptoyz's Avatar
Default J's S1 Troubleshooting Help
I posted this in the under the hood forum, but travis suggested that I move it to the R&C forum.
This is a js s1 balljoint on an 08 cr.
The joint was installed in November with approximately 2k miles on it and maybe 4 track days.
The wet look was from spray brake cleaner but it is not leaking grease
The mounted corner takes considerable effort to bivot while the opposite side with no excessive squealing pivots easily.
What do you guys think?
[media]http://www.youtube.com/watch?v=VXGzu8X2pzw&feature=youtu.be[/media]
Old Mar 13, 2014 | 04:16 AM
robrob's Avatar
As long as there's no excessive play it should be fine.
Old Mar 13, 2014 | 06:12 AM
mLeach's Avatar
These tend to be tight, but it's possible that one wore-in faster than the other.
If you feel like it, and have the tools, I would remove it to inspect the joint itself. With the boot intact, it's unlikely, but I have seen damage to the actual socket. Often this is the result of someone using a pickle fork to separate the ball joint from the control arm.
To inspect the boot, remove the ball joint from the knuckle and LCA. remove the metal retainer clip from the dust boot, and pull the dust boot off the joint.
After inspection, repack the boot with high quality grease, but don't over do it. It will ooze out when the boot compresses during install and make a mess.
Old Mar 13, 2014 | 01:33 PM
gptoyz's Avatar
thanks guys
The balljoint articulates without any kind of inconsistent hesitation or increased force, it's just much stiffer than the opposite side, stiffer than either the other 2 s2ks that all got the J's S1 at the same time. Not to mention it also makes that awful sound.
Old Mar 19, 2014 | 04:39 AM
josh7owens's Avatar
Better than my video
http://vimeo.com/38759212
Old Mar 19, 2014 | 05:27 AM
Gottabfast's Avatar
Does it make the noise at any point in the rotation or at a specific point/area every time? Usually with ball joints, sound is your warning that something is going wrong. The number of things that can happen that cause noise without increased friction or faster wear is small. If grease isn't preventing pure stud to seat contact it's probably on borrowed time.
Old Mar 19, 2014 | 10:38 AM
gptoyz's Avatar
Yes it squeaks like a stuck pig in every direction of articulation
Sent from my SAMSUNG-SM-T217A using Tapatalk
gptoyz
Mar 10, 2014 01:16 PM
macr88
Drivetrain
Jan 18, 2010 12:56 AM
Homer Simpson
Mar 3, 2009 09:44 AM
Psilos
Κινητήρας - Μετάδοση - Περιφερειακά
20
Mar 26, 2007 01:38 AM
