K20C1 Type R Engine in S2K?
yes, intake / exhaust side are different, that will be complicated just to figure that out. fuel / ecu setup will be costly, most likely going to be running motec. we should be having more update sometime next year when time permits to start the project.
the way I see it, the only reason to do this is to say you did... from a performance point of view you can just turbocharge the stock engine. and spend the money you saved on 3 years worth of track days and tires and gas... or a second car...
The K20C1 is more an emissions and fuel economy motor than a performance engine. The power output OEM isn't that great for a 2L turbo. The head doesn't flow that much. There is no VTEC on the intake. the exhaust manifold is built into the head and water cooled.
The F-series and K-series Honda engines may lack direct injection, but in virtually every other way, they are superior.
You guys looking for a car to do this swap with? Local clean ‘06, willing to help with the investment!
