K24 into S2000 Race car SCCA build
Subscribed. I'm running STU for the rest of this year and next. It was frustrating having the corner speed in T2-T10 but being pulled on the straight at Laguna lap after lap.
How much more does the K24 weigh?
A road race K24 making 300 whp is a tall order. I've been racing and building K24 for few years. My World Challenge K24 only making 275 WHP. Yes, it can make a few more HP if we do some exotic build, like smaller wrist pins, lighter materials custom pistons, and so forth. But that engine only last 7 race weekends before it starts loosing power. Realtime guys use fresh engine only for 2 race weekends, and use 2 more weekends on the used engines for practice.
Drag engine will make more power. Street engines also makes more power, and these guys think they are reliable. In most parts, they are correct, because no matter they claimed they taken it to redline all day long, it doesn't compare to a day of racing.
I realize it's a tall order. I'm expecting RPM will be the death of it, So I plan to use the Revs only when needed. It will make more power then the F22... it will make more TQ then the F22. Simple math shows both. It is about the same price to rebuild as the F22... Nope cheaper cause you don't have to sleeve it. The car runs pretty close to the WC cars now with A LOT less hp. If it can make within a few hp of the WC cars it's weight advantage should be enough to close the gap. It should have better weight distribution and better aero then the WC cars. I'd like to make more power but save that motor for one particular weekend....
I Saw his article. It was kinda the... Ok this can be done point of the project. He did things a little different with the custom manifold. I believe he also did the K24 block with a K20 head if I'm not mistaken.
COST SHEET
K24 engine (K24a1 CRV) $800 complete
Adapter Plate $200 (made and designed by me)
Flywheel $500 (custom Clutch Masters piece)
Engine harness conversion $100 (modified Rsx harness)
Mounts $300 (needed to be customized to work)
Fuel system $250-$500
Intake Manifold $300-$800
Header $50 (cost of K flange and welding)
ECU $995(K-Pro) + Core
Read more: http://www.hondatuningmagazine.com/t...#ixzz1WY7daLP3
COST SHEET
The Issue I have is the TSX head doesn't flow all that great so to hit the power numbers I'm going to have to have some decent head porting done. I'd love to run the RSX Type S head but it's not legal to missmatch heads and blocks in the class so I've gotta deal with the TSX stuff.
For TTC I'd do a CRV block with a RSX Type S head.
The build the way I see it to exceed S2000 hp on a K24 is cams. I've talked to several RSX guys that put (Accord,Element,CRV) 2.4 bottom ends under their K20 heads and a set of Cam's and valve springs and fired off numbers in the 240's.
