Koni Yellow rebound damping settings
Old Jul 25, 2011 | 03:43 AM
kleecker's Avatar
Default Koni Yellow rebound damping settings
Have been running Koni Yellows with 440#F, 380#R G/C springs on the track. Never tracked the car with stock suspension, so nothing to compare to but current setup. Intermediate driver, OEM stagger, R-S3's.
Out of the box, I set the Koni's to 3/4 full rebound. I have not experimented with the setting, as the LR shock is a PITA to adjust, due to fuel line. I do not believe I have the ability to sense small changes in damping - just not that experienced of a driver yet. Perhaps from something like 1/4 full to 3/4 full, but guessing at that.
Is there any way to ballpark where these things should be set (perhaps based on all the other S2000's running them?), or are there too many variables to even suggest something?
Old Jul 25, 2011 | 04:15 AM
dan_uk's Avatar
It sounds like you are about right I could tell a difference between soft and full but in the middle not so much.
I try to run as little rebound as possible I'm not sure if this is the right strategy.
Going full stiff didn't help my laptimes when I tested, on 600/500 springs at full stiff I felt like the car was jacking down. So on your springs I would say be carefull going to high - it felt like the car was sinking down around a long sweeper it felt numb.
I think the total is about 1 1/2 turn but don't go past the last 1/4 at each end.
I would start out about 1/2 turn and go up and down 1/4 turn from there. I tried running 1/4 turn less in the rear and definitely like that.
I think I ran about 1 turn front 3/4rear... with them revalved I run about 3/4 turn front 1/2 turn rear.
One thing I noticed messing with the settings at auto-x one setting made the car feel a lot less snappy and easier to drive but ended up going slower. When I put it back to the twitchy setting I was faster right away.
Old Jul 25, 2011 | 04:33 AM
kleecker's Avatar
a bit confused on your settings - are they relative to full hard or full soft? guessing soft.
I think we are using different nomenclature. When I said "3/4 hard", I meant 3/4 of the way from full soft to full hard (1.5 turns x 3/4=1 turn from full soft), not 3/4 turn from full soft. So that's where I have been - 1 turn from full soft, or to say another way, 1/2 turn out from full hard.
Old Jul 25, 2011 | 06:18 AM
dan_uk's Avatar
I mean from where it stops, so dial it back soft till it stops then forwards 3/4 turn thats how I do it
Old Jul 25, 2011 | 07:27 AM
BowlofRice's Avatar
Not to thread jack... But what if it were the same variables except a 255 square setup?
Old Jul 25, 2011 | 08:45 AM
robinson's Avatar
Unsprung mass is not effected by rebound.
Pick rebound settings that match your spring rate and pick bump settings to match unsprung mass (wheels, tire, shock, control arm weight).
Old Jul 25, 2011 | 11:11 AM
BowlofRice's Avatar
Ahh I see. Thanks always for the help Robinson!
Old Jul 27, 2011 | 03:45 AM
kleecker's Avatar
Anyone else chime in wtih their suspension setup, including Koni rebound damping?
Old Aug 1, 2011 | 06:00 PM
Rodney's Avatar
Originally Posted by kleecker
Anyone else chme in wtih their suspension setup, including Koni rebound damping?
07, stock, prepped for solo w/ yellas. i run full soft on street, and full stiff for solo. seems like they dont have enough damping for what i want, but they were cheap.
JDMQuip
Oct 4, 2012 07:41 PM
chubbychu
May 23, 2012 04:22 AM
johnyboy32
Sep 13, 2005 01:32 PM
MarchHare
Mar 4, 2004 08:15 AM
s2kpdx01
Sep 29, 2003 01:51 PM
