KW V3 Alignment
The 2000-2003 shop manual lists front toe as 0 plus/minus .08 so .05 is ok but 0 would be better. It does look like they set .25 inch toe-in on each rear wheel (.5 total) which is twice the .25 total in the shop manual. If they did set .5 total that must be reduced or your car will handle strangely and the rear tires will wear quickly.
Here's my S2000 alignment web page: http://robrobinette....00Alignment.htm
I thought I read somewhere OEM spec was around .56 total or something like that?
If you haven't done much autocross before, then just go. It'll be a good learning experience no matter how your car is setup. Then, when you change the settings and go back again, you'll have a better understanding of what those changes did as far as handling characteristics and whether or not this setting or the new one suits your driving style/setup.
It's hard to tell if you don't have much time behind the wheel. i'm sure you'll have fun either way, so i say just go.
Definitely not my first time... I just don't do it to win. I do it for fun and to improve my skill level.
Yeah I'll probably have fun as long as it doesn't throw off the handling too bad... I just don't want it to eat up my tires too bad. Its 120 miles round trip to/from the site + my runs...
You should be fine for the 120 mile round trip with an extra quarter inch of toe but try to get it reset ASAP. I'm not sure how the car will handle for you but it might actually help since your rear tires are so big. You're just running a little pre-slip angle back there. Good luck.
I told them to use OEM specs except "-1.5 camber all around" (as per your suggestion) and ".28 total toe in degrees" (as per suggestion of another member on here... seemed like a happy medium between the 0.2 someone else suggested and stock, so I thought I'd give it a shot...)
Here is what I got:
Here is what I got:
.25deg per side, 0.50deg total, *is* twice what you asked for, you might take it back and have them give you what you wanted!
In my experience, too much toe (IMO, 0.25degrees per side, 0.50degrees total, is excessive), sucks for absolutely everything. Made my car's handling more squirrelly, but at the same time less pointable at turn-in. Tire wear is RIDICULOUS. -2 degrees camber with 0.2 degrees total rear toe will give you about twice the rear tire life that -1.5degrees camber at 0.5 degrees total rear toe will.
I've tried the gamut of toe settings, from 0.15degrees total to 1.0 degrees total.
In my experience, the car behaves more linearly and *less* twitchy with less rear toe vs. a lot of rear toe. AND you get much greater tire life. AND the car does a much better job of finding the apex and generally going where you point it.
I'd ask them to set it where you told them to.
Here is what I got:
Here is what I got:
Anyone else have any other recommended changes or does everything else look ok? I know it won't be perfect the first time and will need to be dialed in to my preferences, just trying to get a good starting point.
