KW3 Question
Old Sep 1, 2006 | 07:21 PM
Kel's Avatar
Kel
Originally Posted by Raymund,Jul 9 2006, 08:36 PM
I noticed that on mine as well. Anybody else?
only 2 of my shocks are like this. Its probably just how the valve was installed when they build the shock.
payneinthe's Avatar
thanks! I checked their site and couldn't find it. Guess I suck
Old Sep 1, 2006 | 07:22 PM
3312DC's Avatar
Originally Posted by payneinthe,Sep 1 2006, 06:45 PM
I can't find my manual. Anyone care to post the highlights of the adjustment instructions?
start with all the valves closed and make your adjustments from there
last event I was 1 turn up front on top, 1.5 in the rear
.5 on the bottom all the way around.
got those from another local member
Old Sep 1, 2006 | 07:25 PM
3312DC's Avatar
Originally Posted by Clark,Jul 9 2006, 07:23 PM
3312DC, you are describing the adjustment that I'm talking about. Yes, the opening does allow for approximately 1/4 turn only.
However on 2 of the shocks, when I closed the valve completely per instructions, the hole/pin was in the middle of the opening, not all the way to one end (the other two were all the way to one end),
my front two were like this, full stiff/closed was in the middle of the travel
Old Sep 1, 2006 | 07:29 PM
payneinthe's Avatar
when they say clockwise, is that looking from the top of the shock or the bottom?
Old Sep 1, 2006 | 08:04 PM
mikegarrison's Avatar
All else stock?
Old Sep 3, 2006 | 07:56 PM
3312DC's Avatar
Originally Posted by mikegarrison,Sep 1 2006, 08:04 PM
All else stock?
RA-1s and a Gendron bar set at hole 3... 1 being softest-6 hardest
thats it suspension wise. car was solid. tires were 35-36 degrees when hot
Old Sep 3, 2006 | 10:38 PM
payneinthe's Avatar
I too found 7/8 compression and -0.5, -1.5 rebound to work well. My suspension is not very stock, though.
Old Sep 5, 2006 | 01:12 PM
gfacter's Avatar
Those are some cold tires, where are you racing the North Pole?
Old Sep 5, 2006 | 07:14 PM
3312DC's Avatar
smart ass.
thats probably why you were faster, getting me to keep lowering my pressures
