KWV3
So I am trying to figure out where I should set the ride hieght for my KW's, and figured I would put the question out to you guys. Trying to get the car setup for Road Atlanta.
Anyone please feel free to chime in.
As the car sit's right now it's at 3 3/4" front and 4 1/8" rear at the jack points.
What do you run for compression and rebound?
Originally Posted by WynnS123,Nov 22 2010, 12:45 PM
I have my V3's set at 3.75" front and 4" rear from the floor to the jacking points.
As far as rake, I liked a bit, about an 1/8-1/4 delta in order to get a bit better turn in/response from the front.
Originally Posted by Antonov,Nov 22 2010, 01:29 PM
Thats about where I had my CS's set @. My fronts once somehow ended up dropping down to about 3.5" and with the 571# springs I was hitting bump stops @ SOW, so if you guys are running the standard 460/515# V3 rates, I wouldn't go much lower than 4".
I've driven a 571/571 V3 at 3.5"/3.5" front and rear ride height and it didnt bottom out at SOW.
Originally Posted by Billj747,Nov 22 2010, 07:46 PM
What swaybar were you using?
Originally Posted by PrOsPeCt S,Nov 23 2010, 08:58 AM
Billy I'm trying to get the car set up for Road Atlanta and was hoping that you would chime in.
I was about 3.75"/4" the other week at roebling it was fast but totally non pliant just flat it wasn't working good at all in T4>T5 etc.
I am raising mine up to around F/R 4"/4.5" and dropping the springrate to try and make it more driveable for Road Atlanta.
skips car was a good 3/4" higher than mine at RA in June and he was allover the kerbs
