KWV3
Originally Posted by PrOsPeCt S,Nov 28 2010, 12:52 PM
cornered balanced the car yesterday,
LF 733 RF 686
LR 714 RR 668
Total 2801 49.9% cross 1/4 tank of fuel with me in it.
LF 733 RF 686
LR 714 RR 668
Originally Posted by 3r1k,Nov 28 2010, 06:00 PM
Is having your car too high would affect much on the handling?
I can't lower my car too much due to the design of J's Front Bumper.
I am on 10.7 cm (4.21 inch) and 11.2 cm (4.4 inch) so it has 0.5 cm rake (0.2 inch). The measurement from ground to the fender would be 64.5 cm (Front) and 65.5 cm (Rear).
I want to give your suggestion a go Billy but not sure if I can go down to 9.5 cm and 10.5 cm ride height.
Lower Center of Gravity = better (within reason of suspension geometry constraints), but 4" should still be more than acceptable. Your ride height will most likely be fine.
0.02
It should be easy enough to get around 2800 with that setup did you weigh it?
I have the HD bar with gutted rear and softtop it was 2820lbs at Roebling with half a tank and 190lbs of me.
the airbag stuff out thats an easy 10lbs+
lightweight battery is an easy 10lbs+
Do you guys still have AC, heat, cruise, stereo, and air bags?
