Low compression motor concerns
Old Mar 10, 2015 | 12:49 PM
BoostedE21's Avatar
Default Low compression motor concerns
So I dropped a valve at BW and pretty much, the motor is done for. I have a friend that has a spare motor that has low compression (180-190 across the board?) that I am thinking of getting, however, here is my question:
Can I change the rings ONLY (assuming everyone thing else is fine) and be okay? If I have to hone it, I might as well get a different block and work with that since I can use some of my stuff from my motor. My concern is that the rings wont be enough to have a proper seal due to the cross hatches being worn. I am not sure how that works with the cylinder walls on F series motors.
I have experience with building engines, but that's with traditional motors that can be bored etc.
Thoughts?
Old Mar 10, 2015 | 04:21 PM
dan_uk's Avatar
If the compression is the same across the board the motor could be ok and the gauge is probably out? I have one gauge that reads 240psi+ and one that reads about 180psi on a healthy motor I've crossed checked it on maybe 3 engines and my own
About the rings I had a block recently that I think had ring failure but no scorring. From researching on google etc I couldn't work out whether it could be re-ringed wuthout a re-hone if the block was no scorred.
I sold it cheap to a friend who was going to do a re-ring and see how it goes since it seems like its a bit of a crapshoot
Old Mar 10, 2015 | 05:55 PM
anorexicpoodle's Avatar
Top Answer: 1
Were those numbers produced on a cold or warm motor?
Theres ~35psi of delta cold to hot.
Old Mar 10, 2015 | 10:01 PM
06Estukay's Avatar
+1 for temperature of motor affecting readings. Was it done cold? If so, that could affect the readings quite a bit. Look for consistency across.
Like one of the guys said, some gauges read different. On my motor I've seen as low as 180 on one gauge, and 225-230 on my gauge.
Yes, you can reuse the pistons and install new rings, as long as you hone the cylinders. Not bore, but hone... there's a big difference. You'll need to find a machine shop that has the right honing tool for the FRM sleeves.
Double check the motor first before digging into it.
Old Mar 11, 2015 | 03:53 PM
BoostedE21's Avatar
Thanks guys, ill be doing a leak down test to figure this out before I proceed. I am not sure if the comp test was done when it was cold or hot, was just told low comp.
Spoke to someone that it may not be a good idea to put new rings on used piston and walls. The cross hatching is already worn and the cylinder might not be a perfect circle and could cause additional scoring.
Thoughts?
Old Mar 12, 2015 | 04:35 AM
dan_uk's Avatar
Thats what i read you have to rehone but the rehone for a fibre block maybe very expensive
mikizzle
Jan 10, 2013 10:29 PM
Volked_S
Jul 25, 2010 07:04 PM
