Lower oil temps with canton pan
With the larger capacity & surface area has anyone seen lower oil temps with the canton pan.
https://www.cantonracingproducts.com...EDRAG-OIL-PAN/
Going from the oem pan to a canton pan I saw something like 20-30F higher oil temps at the track and higher oil temps on the street.
The OEM pan helps considerably w/ oil cooling. If you track your car regularly it's probably a good idea to run an oil cooler w/ the canton pan.
Originally Posted by SlowTeg
Going from the oem pan to a canton pan I saw something like 20-30F higher oil temps at the track and higher oil temps on the street. The OEM pan helps considerably w/ oil cooling. If you track your car regularly it's probably a good idea to run an oil cooler w/ the canton pan.
