Mmm, coilovers
Old Mar 24, 2003 | 09:37 PM
jzr's Avatar
jzr
[QUOTE]Originally posted by ultimate lurker
[B]I'm sure that as soon as I go coilovers, the other folks in my class will have added some other part to help keep them ahead of me anyways - its an arms race :-).
Old Mar 25, 2003 | 12:09 PM
Strike's Avatar
PFB- The setup I have is the full setup from GC - Coilovers with their AD shocks. The spring rates are 380/450.
Jason - Re: your point about the aftermarket suspensions not doing much for the S2K at the track. My first thought is that you might be right. However, I also think that confidence inspires speed. You must trust your car to be willing to go as fast. I feel much more comfortable in the car now than I did with the stock setup and I think that will translate into faster laptimes for me. I also think (but have no evidence to support this theory) that with a better driver who is much closer to the limit all the time than I'm capable of, the upgraded suspension may make a difference in laptimes.
Old Mar 25, 2003 | 12:54 PM
twohoos's Avatar
Another data point: I ran Hoosiers and stock shocks/springs and found the car fast but much less stable than slickrick's car, which had coilovers/RA1s. I consistently got big-time wheelspin cresting Lost Hill, and generally had trouble getting the power down out of the corners. Looking at photos of my car after the event, I realized why: my inside tires were nearly off the ground in the turns! So of the two setups, I think coilovers/RA1s definitely has more potential, especially, as Strike says, for those of us who benefit from the feeling of confidence that the extra stability provides.
Old Mar 25, 2003 | 01:49 PM
krazik's Avatar
Administrator
slickrick had a wing too.
Old Mar 25, 2003 | 04:07 PM
twohoos's Avatar
Yah, but it wasn't the wing. His car was completely buttoned down (with, admittedly, 700lb springs all around!). In comparison, mine could make you seasick from all the bouncing/floating. Those big Hoosier sidewalls weren't helping my cause either...
Old Mar 25, 2003 | 04:42 PM
krazik's Avatar
Administrator
sidewall shouldn't be a problem, you're new w/ the hooisers right? You'll find that they hold just fine and get used to a little bit of sidewall flex before they really stick. It took me a whole weekend at sears to get used to how to load them up.
Are you running 225/275?
Old Mar 25, 2003 | 08:56 PM
rlaifatt's Avatar
[QUOTE]Originally posted by jzr
[B]As a side note, I recently had a chance to do a lap or two in a massively lightened (~20% lighter than normal ) S2000.
Old Mar 26, 2003 | 08:42 PM
Renos2k's Avatar
I just added on the JRZ's, a Gendron sway bar and Hoosiers- simply awesome.
Old Mar 26, 2003 | 11:08 PM
krazik's Avatar
Administrator
yeah the JRZs are an awesome shock too.
Old Mar 27, 2003 | 05:32 AM
rlaifatt's Avatar
JRZ's
Does anyone have numbers for determining the rake of the car stock, what the actual measurements front and rear are and what reference points were used? I believe that, ideally, the measurements should be made from reference points on the frame to the ground.
