Mmm, coilovers
Old Apr 1, 2003 | 10:46 AM
  #61
krazik's Avatar
Administrator
just about all aftermarket shocks can be rebuilt. The problem is, does the shock you have, have a US office to rebuild them or do you have to send them to the mfgr.
The latter would take a lot of time and $.
Old Apr 1, 2003 | 10:51 AM
  #62
S2kRob's Avatar
Krazik, what exactly does triple-adjustable mean? Damping, compression and what else?
Also, can you post pics of your JRZ's installed?
Thanks.
Old Apr 1, 2003 | 11:02 AM
  #63
rlaifatt's Avatar
[QUOTE]Originally posted by gernby
[B]
I'm sure it does, but I think that is true with any damper.
Old Apr 1, 2003 | 11:05 AM
  #64
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by krazik
[B]just about all aftermarket shocks can be rebuilt.
Old Apr 1, 2003 | 11:15 AM
  #65
SAIYAJIN's Avatar
[QUOTE]Originally posted by S2kRob
[B]Krazik, what exactly does triple-adjustable mean?
Old Apr 1, 2003 | 11:30 AM
  #66
SEVNT4's Avatar
Gernby,
I think Docofmind also mentioned that JIC has a US based facility in SoCal. I found this http://www.jic-magic.com/
JIC USA
12229 Woodruff Ave.
Downey, Ca. 90241
Tel: 562-803-6122
Fax: 562-803-5012
The more I consider all the factors, I may go with JIC when my stock suspension needs changing.
[B]
I'm about to order the JICs.
Old Apr 1, 2003 | 12:40 PM
  #67
davepk's Avatar
[QUOTE]Originally posted by SAIYAJIN
[B]
Damping, compression and rebound.
Old Apr 1, 2003 | 03:49 PM
  #68
SAIYAJIN's Avatar
My mistake. Thanks Dave for correcting me
Old Apr 1, 2003 | 07:47 PM
  #69
slick rick's Avatar
Race dampers need to be re-built once a year if they are of the shim stack type, depending on the frequency of use. Sometimes you can go 2 years.
What happens is the fluid gets dirty and loses it's consistency, just like having to do an oil change.
In any case, it's always better to have a local "center" nearby in case something goes wrong or if you need re-valving.
Old Apr 5, 2003 | 11:03 AM
  #70
Wael El-Dasher's Avatar
JRZ's never need revalving because they do not use needle valves. Here is a blurb from our website, "Unlike virtually all other dampers, including Ohlins, this design does NOT use a needle type valve to adjust the damping characteristics. Instead a plate type is used, exactly like racing vehicles, to eliminate non-linear damper response, a side effect well known with needle valves"
Estimated rebuild period of 5 years on race vehicles, probably translates to 8-10 years on street.
Hope this helps
cheers
W
