Momentum Time Attack Build
Old Mar 13, 2010 | 06:14 AM
  #21
Momentum's Avatar
Only oil pressure issues are cornering related I drop oil pressure briefly even with the baffled pan. I would bet most guys with slicks on here do but it's too fast to see on a gauge.
Old Mar 13, 2010 | 06:40 AM
  #22
cracknut's Avatar
Do you have oil pressure logged in the Motec? It's handy to correlate lateral Gs and oil pressure.
Old Mar 13, 2010 | 08:04 AM
  #23
EVAN&MONICA's Avatar
THat is gonna be such a monster!! good work!
Old Mar 13, 2010 | 04:52 PM
  #24
iApex's Avatar
Are you running an accusump?
Old Mar 13, 2010 | 06:18 PM
  #25
SC_Highlander's Avatar
Originally Posted by Momentum,Mar 11 2010, 09:17 PM
Space was tight today as the car was on the lift surrounded by cars. It is by far the ugliest S2000 you will ever see though
At least yours is mostly the same color....
Old Mar 13, 2010 | 06:43 PM
  #26
Momentum's Avatar
I am logging oil pressure and g's but dont have an accusump... Apparently I need to paint a few more body panels to take the title o ghettoest s2000 in the country
Old Mar 13, 2010 | 08:01 PM
  #27
A51_AP1's Avatar
I took the liberty of resizing your images for you
Old Mar 13, 2010 | 08:43 PM
  #28
iApex's Avatar
How low is your oil pressure dropping in sustained sweepers? What's your sustained G's if you don't mind me asking?
P.S Thank you for resizing those pictures A51_AP1!
Old Mar 14, 2010 | 08:41 AM
  #29
Momentum's Avatar
Thanks for resizing those oil pressure drops about 40psi below normal in the worst cases but briefly... I've taken the motor apart and checked the bearings and they look fine so I'm not really concerned anyway. With a stock motor and 600hp I doubt the bearings will be the first to go anyway . Sustained g's are about 1.5
Old Mar 15, 2010 | 12:14 AM
  #30
A51_AP1's Avatar
no problem! I just use photobucket. they auto-format the images
