Motul RBF 660...
I went to buy some bottles of Motul RBF 600 and saw the RBF 660 next to it. I contemplated going with the 660 formula but wanted to ask you guys whether or not it was overkill for my purposes. I'll be tracking my car approximately once a month, do you guys think RBF 660 is too extreme?
Will you wheel-to-wheel racers use it?
Motul RBF 660 Specifications:
DOT Rating - 4
Dry Boiling Point - 617
DOT Rating - 4
From: 13851 A Better Way #11D, Garden Grove, CA 92843
RBF660 has a higher boiling point dry than RBF600, but a lower boiling point wet. This means it absorbs water at a higher rate than RBF600. 660 is pretty much for high performance cars that constantly bleed out the fluid. (race cars) I've spoken to Motul on a couple of occasions regarding this. I use 600 and bleed brakes every 4-6 months. No need for 660.
I've heard around 6 months to a year for street driving on Motul 600, but that is debatable.
ATE Blue states its fluid is "high performance brake fluids that have both a high dry boiling point (536 deg) and a high wet boiling point (392 deg), but without being excessively hygroscopic. What this really means is that these fluids do not readily absorb moisture like most high performance fluids."
They claim it does not absorb moisture as much as others to excuse the low wet boiling point. Not sure how to confirm this. I've never used ATE. I aways wondered how do you know when ATE is dirty since its dark blue.
Originally Posted by Voodoo_S2K,Apr 10 2008, 02:34 PM
I'm a big fan of ATE Blue. Been using it now for 5 years without any problems. Even though it is a colored, you can still tell when it gets dirty by the color shade change.
