My S2000 at Cota
I had to re-learn to use the curbs as part of the track, EU style and not just killer spots, TX style...
Beside the routine trackday checklist i'd say you want to focus on:
Brake flush and track oriented pads and rotors
Good alignment to allow stable trailbreaking
Suspension setup pretty hard, no bumps here!
Originally Posted by rohde88' timestamp='1358884557' post='22283937
stock pads? crazy to have all those mods, but not pads.
I talked to Rick from DE and he was really happy with that event. Can't wait to go myself
How much pad did you go through in a weekend? Just planning for pit stops...
@CKit , yes, I am sure XP12 in the rear calipers. That's the way I like the brakes on the S. Before when I was tracking my DC2 I was using front DS3000 and the rears...I don't even remember! But we can't compare apples with bananas.
I did 4 sessions, out of which only 2 pushing hard on the brakes. I had my fronts pads at just a tad after the middle groove (i don't know how to explain it, the carve that splits the pads in two halves). Basically you could not see the middle groove.
At the end of the day I had zero-niet-nada-nothing left (don't tell the TD organizers, I was supposed to have 90% as per rules but I only had new OEM pads at home so...
). I'd say I used 1/5 of the pads on that day.
Did I already mention to flush the system and use superblue?
). I'd say I used 1/5 of the pads on that day.Did I already mention to flush the system and use superblue?
I made it to the track for the F1 race, absolutely amazing. It looks like you had a blast! Re: the KW V3s, I think you'll be pleasantly surprised by the ride quality. I have Clubsports with stiffer spring rates than the V3s and I felt they had the same ride quality as stock.
The speed you have to scrub off at the ends of the main and back straight have to put a ton of heat into the brakes. I'd highly highly recommend rigging up some type of brake cooling.
$30 worth of ducting along with some zip ties:
https://www.pegasusautoracing.com/pr...p?Product=3620
Your pad life should improve along with improving the life of the calipers, bearings, all the parts in the brake system.
$30 in reusable ghetto brake cooling probably would save you hundreds in brake pads
(I just saw your updated pad wear).
http://www.kxan.com/dpp/news/local/a...-cota-track-ig
