NASA TT Help
Originally Posted by Mrsideways' timestamp='1301068070' post='20395973
[quote name='Richard EVO' timestamp='1301066484' post='20395847']
R-888 is absolute garbage. Don't touch them. NT-01 far better.
You need to get the extra 72 lbs. out of the car. You need to be as close as humanly possible to the minimum weight with maybe 1/4 tank of gas in the car. It matters.
[/quote]
Yep, same exact sizes, same wheels and YES the NT01 race tire vs the XS street tire. And you'll find this odd but the XS's were TERRIBLE in wet testing. Like Hoosier Dry kinda terrible. Yet I ran the NTO1's in a rain soaked race at sebring in 2010 on the Focus Showroom stock car and nearly lapped the whole class. (2nd place car was on Hoosier wets). I ran the NT01's that day because we had a set and I didn't have Hoosier Wets. I expected to be fighting for last. I'm not claiming the are better then a hoosier wet but my goodness they were a lot better then I expected. I stuck my nose in the tire tracks left by a car a class higher then me on hoosier wets and just did my best the whole race to drive in the wake he spread. It worked.
Anyway, my point being the NTO1's are not an R-compound (atleast not in the same league as a Hoosier or BFG or Kumho).
I have some tore up old 255 R888's and I don't think they are more than 2 seconds slower than a 225 A6 in the cold
I might not be using the A6 100% but the R888 is a step up from RE-11's and those are the best street tires I ever ran.
I don't think you need a big front swaybar with a wing unless you love understeer!
The 06+ with the remap is the car to have it has more horsepower class it as an AP2 to start
ok well I guess it varies with preferance wing etc but you can save some points there if you have suspension
I always ran a bar before I had shocks - taking the bar off mine was a revelation!
I run more rear-toe now so the thing is more stable and I set the shocks and wing
Good to see another CR owner doing TT! A few notes
1) You don't have to add +2 for 255 tires. 255 is the base class tire size. I was confused at first too being that the S2000 is staggered
2) You can't take -1 for 255 tires in TTB. It's based on your base class.
3) Consider reclassing your car as a non-CR. Play with the points and see if you can make a better classed car. For example, I totaled up your current points to 29. If you remove the front lip and take 2 points for the CR chassis bracing and 5 points for the wing, you could classify yourself as an AP2 with 22 points. Then you can replace the CR wing with a proper GT wing and still be at 22 points. Or take out the chassis bracing as well and maybe the intake or the test pipe and run TTC with 19 points. The combinations are endless. (I asked on NASA forums. The front lip takes a ton of points for a regular AP2 since I think they consider it a different fasica, lip, and canards).
Per your questions
1) Hoosiers. The contingency plan is awesome if you're competitive and the car is ridiculously fast. I run 225 R6's for 3 points and they're well worth it. Otherwise, I really liked my RA1's. I was within a quarter of a second of a TTC lap record on JUST Ra1's (stock CR) when they were 5 points. Lap record was set that day, previous session.
2) not sure
3) No. Stock seats and bar are fine. Roll bar is a good idea and can replace the chassis bracing if you do decide to class yourself as an AP2.
4) 4 or 5 15 minute sessions. Fair amount of seat time - probably a little less than a typical HPDE.
5) I know the car can be competitive in TTC. TTB as well, but I think thats where the S2000 starts to lose its advantage. You could get a good driver in an STI that has enough boost to be a problem on tracks with long straights.
Per your questions
2) not sure
I understand the weight issues, as well as the deal with the CR aero. 14 points seems to be a lot and the front lip may not be worth the points, plus i'm sure that a different (adjustable wing - J's or something) would be better than the stock CR wing. I would also have to do the A/C delete (about 50lbs) and look to trim weight in other ways (ie: seats), the problem I have is i still owe about $15k to the bank, and i don't want to alter the original look of the car because i love it. plus if i remove the A/C my wife will never drive with me ever again.
I think until i get to HPDE4 i'll drive it as is and figure what the next move will be. I was on the fence about fully prepping my CR for TTB (if it could compete), or just trying to find a track-ready, non street legal TT car that i could trailer to events and beat on. I would consider an old Miata or something, so i'm trying to guage the cost of competition (brakes, tires, gas, spare parts, wheels, etc). A Miata would be fun and cheaper to track, but i really love the S2k, so maybe i could find a race ready TTC s2000 in the future.
Anyway, ramblings aside, i have a couple of questions:
1- Hoosiers - i figured it was a no-brainer, but how many events can you expect to get out of a set of 4, assuming i'm non-staggered and can rotate them? That's still gotta get real expensive.
2- I was looking at used '06s (Hondata Flash-Pro compatible) and they're going for about $16k right now. If i were to stick to TTC (the s2k's best class) how competitve are the AP1s? how about an '04-'05 AP2? $16k is a bit steep of a starting point for me to prep a TTC car. But from my experience with the Flash-Pro, my CR picked up some serious mid-range gains and 13 peak hp at the wheels, so I'm assuming a re-flash of some sort is a 'must have' to be competitive. Especially when the cost is 0 points.
HPDE4 is for instructors, you only need to get to HPDE3 and get a checkride to TT. If you've been on the track around 10 times maybe try to go straight to HPDE2-3.
If you stay learning to drive 100% in HPDE with Nasa it might take u a while to get to HPDE3. The best thing to do is get out to trackdays where you get more seat-time and practice. Turn One Events at CMP and seat-time.com at Roebling are good places for cheap seat time in the southeast.
As for the car I realy wouldn't worry about the setup too much to start out, a CR is more than fine for HPDE/learning.
I used an AP1 with a lowerring springs and street tires for about 2-3 years before I built mine for TTC.
You got to remember its not just going fast or whatever for the checkride. TT is open passing and you will be on track with 100HP Civics as well as Time Attack/Racecars with silly amounts of power. You have to not be able to freak out when a 700HP Supercharged Viper comes up the inside of you thru the Kink at CMP! It helps if you can think about slower cars and be able to maybe wait a few corners and pass them on the straight where you won't f@#kup their lap.
I'll be out at the CMP event, that'd be a good place to start: http://www.nasa-se.com/2011Apr30.php
turbo8765
Jul 19, 2011 03:51 PM
leets
Oct 10, 2008 12:41 PM
