Need new axles, but where from?
Old 05-12-2018, 09:05 AM
austincrx's Avatar
Default Need new axles, but where from?
At the end of last season I had an axle boot rip open. I replaced the axle with a new aftermarket one, which was around $120. That axle lasted 45 minutes and then broke. This is a car with 220 whp, 125 ft-lbs, so not a power thing at all, just a junk axle. That being said, the HONDA axles are $600(!!!) each, so where can I get a GOOD axle that will last at least a few seasons on track? This is a race-only car, so no daily driving, and it only gets on track for 2-300 miles per year (sadly, but we all do what we can, that's life).
Maybe my aftermarket one was just a bad axle (but the entire outer bearing race was destroyed, so it seems like it was a bad design or just really cheap components, which will be the same for all of that company's axles).
Thanks everyone!!
Old 05-12-2018, 10:55 AM
Chibo's Avatar
Did you throw out your OEM axle? Buy the boot kit from Honda for $25 and a GOOD boot clamp tool. It is a pretty easy job, even without removing the axle from the car. The Honda kit comes with a new c-clip, bottle of grease, two clamps, and a new boot.
Old 05-12-2018, 01:01 PM
fly_S2K's Avatar
+1 on OEM rebuilds. I've done the aftermarket re-man route many moons ago and after spending more time swapping out axles then being on the track/road, I've completely given up on it. Rebuilding the CV joints is extremely easy. It's messy but very easy. You can buy yourself a clamp
Tool Tool
and use the respective clamps for those tools. More universal and easier to handle. OEM bearings can cost more than a reman, but they will far outlast them based on my experience.
Old 05-12-2018, 01:36 PM
Midnightdennis's Avatar
Try Ballade Sports’ OEM rebuilt axles. Replaced both sides with axles from Ballade. No issues at all
Old 05-12-2018, 02:41 PM
pastoli's Avatar
I am running Gator Racing Axles in my TT4 race car. They take the OEM axles machine the cups if needed and add bigger rollers. They then pack the cups with a higher temp grease with a higher moly content. Then they finish them off by using thicker and heavier duty boots. If you want them to they can paint the axles. I did there sweet lime green option. I broke a non OEM axle hopping curbs last year on my third session ever with the car.
Old 05-12-2018, 06:22 PM
zpeed's Avatar
I heard Driveshaft Shop make some. Maybe for the drag application.??
Old 05-13-2018, 06:05 AM
ajohnson's Avatar
I went with insane shafts lower hp models. No fit up issues and 8 events on no issues whatsoever
they are also a little lighter than the stock axle.
Old 05-17-2018, 05:42 AM
usafstud's Avatar
same here, currently have about 14 days on it in 7 months
Old 05-17-2018, 07:24 AM
Driven's Avatar
I used autozone axles with their lifetime warranty.
Costs around $180 for a pair, then all you pay is nothing.
Sure, they aren't as good as OEM ones -- but, if the boot rips I return it back to autozone and get another one.
LostMarine
05-04-2017 06:33 PM
Olegator
03-30-2010 03:30 PM
revhi
04-03-2008 06:37 PM
Asura
07-22-2005 05:45 AM
The Raptor
01-10-2004 07:59 AM
Quick Reply: Need new axles, but where from?
