NEED NEW CLUTCH / HELP?
Old Jun 4, 2009 | 11:14 AM
Ben22's Avatar
Default NEED NEW CLUTCH / HELP?
Hello all,
Just got back from Tony F. in the SF valley (CA) and he recommended i change my clutch before i join the S2K challenge this month. My MY03 has 57k+ on it.
Without being too extensive, he recommended ACT PRESSURE PLATE and a LIGHTER THAN STOCK FLYWHEEL (comptech).
My car is mainly for week-ends / track driving. Not my DD...
What would you recommend? where would you buy? Kind of in a rush...
I'm sure this question must have been asked a lot, but i cannot seem to find some recent input.
Your help is as always tremendously appreciated,
Cheers,
22B
Old Jun 4, 2009 | 12:51 PM
Integra21's Avatar
I almost posed the exact same question! Except mine is also a DD
Check out the sponsored section. NoLimitMotorsports has a deal on ACT products (PP, flywheel, and disc)
Old Jun 4, 2009 | 12:55 PM
robinson's Avatar
I have the ACT PP and flywheel. Don't remember the dealer. Do a Google search.
However, I don't think it is necessary to go the aftermarket route with stock power, if that's what you have.
I just did it b/c it was cheaper than paying the dealer.
Old Jun 4, 2009 | 01:10 PM
Integra21's Avatar
does "stock power" account for bolt ons?
Old Jun 4, 2009 | 01:31 PM
metros's Avatar
Since bolt ons add minimal power then I would say you could use a stock clutch.
SILAP1's Avatar
yes i think from what alot of peopl her said before stock is just fine and holds up good . Maybe do a search , i just got my new OEM clutch but not installed yet . I got 120,000 out of my clutch so far why not try another OEM
Old Jun 4, 2009 | 02:44 PM
Fast Jack's Avatar
Only getting 57k out of the stock clutch,sounds like need one dats a little tougher.I spun the stock clutch with just 6lbs of boost,it ain't dat tough.Perfect time to up grade and save $$ not having to do it again any time soon.My.02 cents
Old Jun 7, 2009 | 08:28 AM
Ben22's Avatar
To update:
I ended up getting the ACT Heavy Duty Pressure Plate as well as the ACT flywheel.
Highly recommended accross the forums!
Got a great deal from GOTuning.
Thank you all for all your simcerely appreciated inputs,
Cheers,
22B
tn-max
Mar 13, 2007 06:23 PM
TheLoons12
Aug 18, 2006 02:11 PM
MikeyCB
Jun 13, 2006 04:58 PM
NOSNOW
Mar 4, 2006 12:20 PM
cmnsnse
Feb 13, 2001 08:46 AM
