need some cheap stickies
i need some good tires for autox/street purposes. i'd like to not spend too much, and tread wear isn't that much of an issue since this isn't my DD. i'd go with the new falken's (the replacement for the azeni's) but i don't believe they offer them in our wheel sizes.
It's real simple. Stay with the stock tires unless you want to buy another set of rims and race tires (swaybar needed too). You can't do better than the S02s with out buying real r-compounds and you certainly can't find anything cheap that will beat the stockers.
The best R compound for the street is Toyo RA-1's which are cheaper than S-02's (barely). Hankook has the new RS-2 which is intended for ST class auto-x.
http://www.discounttiredirect.com/direct/f...r%2FPerformance
as a disclaimer, he was looking to run competitively in our local street tire class. i assume for someone who wants a good all around tire, these would be just fine. plus, these are so new, not many people have had any experiences, so others may feel differently, but i trust this guy's opinion.
as a positive, these are available in the proper sizes, 205,245, even 225 for the front if you wish, and they are relatively affordable.
so for the Hankook tires on oem 16's the correct tire size would be as follows??
205/50/16 front
245/45/16 rear
let me know if this is correct...as i would like to try these out if they are a good max performance summer tire. Hopefully they will be as good as the stock s0'2 in dry and better in the wet
also are there any other people running the Toyo Ra-1's on the street...i would like to know how they perform in wet conditions...
also where can you get the RA-1's???
205/50/16 front
245/45/16 rear
Just got mine this past weekend, got in a good amount of runs on Sunday to test them out. I'm in love...
