Negative Camber
Old Oct 12, 2007 | 10:40 AM
Turn-R-Us's Avatar
Default Negative Camber
How much negative camber are you guys getting out of the stock arms (lowered preferably)????
I am lowered and getting -2.25........And I need more as I am wearing the middle and outside more.
I am trying to see what can be done without modifying (new arms, SPC joint....)
Old Oct 12, 2007 | 11:10 AM
crash's Avatar
nothing.
if you are maxed out on the adjusters thats it.
I have been tossing up the idea of getting custom offset bushings for the upper control arms but I would not do that on a DD
Old Oct 12, 2007 | 11:21 AM
asng's Avatar
i'm running -3.5 at the rear. max is -3.8.
it's way too much for street tires... but it looks good.
Old Oct 12, 2007 | 11:41 AM
CosmosMpower's Avatar
-1.75 front, -2.25 rear stock 03 suspension on a 00 might be able to get more
Old Oct 12, 2007 | 11:54 AM
Turn-R-Us's Avatar
I have an 03 dropped and getting -2.25.....problem is dont know if I am maxed out.....may need to go back and redo alignment. I have -3 in the back and that appears to be ok....may need a bit more there, but I know there is room in the back.
Old Oct 12, 2007 | 11:57 AM
TJF's Avatar
TJF
Why are you needing that much camber on street rubber????
Old Oct 12, 2007 | 12:24 PM
pongydoo's Avatar
Stock 2000, I am at -2.1 up front and which isn't quite max out yet and running -2.4 in the rear.
Old Oct 12, 2007 | 12:57 PM
JawKnee's Avatar
My AP2 is lowered with KW V3s and the minimum amount of camber I could get in the rear was -2.3 for whatever that is worth.
Old Oct 12, 2007 | 01:56 PM
Turn-R-Us's Avatar
Who said I had street rubber????
It is a track only car.......NT-01
Old Oct 12, 2007 | 01:57 PM
Turn-R-Us's Avatar
Are you lowered at all??
