Negative camber reduction with solid bushings
Old Jun 23, 2016 | 03:31 PM
dsddcd's Avatar
Default Negative camber reduction with solid bushings
Is there anyone that can comment on removing Camber after moving to monoball/bearing suspension bushings. If I was running 3° previously I am assuming there will be less deflection thus I will need more positive camber by roughly half a degree.
Old Jun 24, 2016 | 08:23 AM
freetors's Avatar
I would be surprised if your min/max changed by even a tenth of a degree unless your bushings are totally destroyed.
Old Jun 24, 2016 | 09:01 AM
dsddcd's Avatar
Excellent, I thought that a fair amount of the deflection was the bushing flexing but it must be in the chasis, yaw and tires. I will stick with my original alignment settings.
Old Jun 24, 2016 | 09:12 AM
King Tut's Avatar
The upper control arm bushings can definitely bind and change your alignment if you aren't torqueing them at ride height. Other than that I doubt they will change your alignment much if you reset all the eccentrics to the same location.
samson123
Aug 24, 2017 10:19 AM
shift9k
Nov 5, 2014 04:06 AM
rustyshackle
Aug 5, 2012 07:09 AM
seansniper
Jan 19, 2012 04:08 PM
RazorV3
Nov 14, 2004 08:18 AM
