New 2000-2005 STR ECU option?
Old Oct 11, 2016 | 03:49 PM
solos2k's Avatar
Default New 2000-2005 STR ECU option?
https://www.balladesports.com/produc...ecu-proecu-s2k
If one were to make this fit into a S2000 case would this be legal?
Old Oct 11, 2016 | 04:13 PM
ConeKiller2's Avatar
For that kind of money you would be better off running a tried and true aem or haltech wired as a piggy back. In addition jim reyenga was able to get a megasquirt to run on his ap1
Old Oct 11, 2016 | 05:16 PM
solos2k's Avatar
Easy button, haltech plus harness is the same price and still a piggyback or "trick" in my opinion along with the AEM. My tuner hates piggybacks especially on the s2000's because every ecu reacts differently and have problems sometimes.
Old Oct 12, 2016 | 08:29 PM
DavidNJ's Avatar
I didn't think the AEM was available as a piggy back. AEM and Motec have replacement ECUs which require some tuning and won't pass emissions. If you have a significant modification and are exempt from emission testing then this is probably the best option.
I believe one solution is the use a post-2005 ECU: http://store.evans-tuning.com/hondata-kpro.html
Old Oct 13, 2016 | 06:59 PM
solos2k's Avatar
I believe one solution is the use a post-2005 ECU: http://store.evans-t...ndata-kpro.html
It has to retain obd connectivity and fit in a factory ecu casing or be a piggyback.
sebian
Mar 5, 2015 03:29 PM
s2konroids
Aug 31, 2009 11:31 PM
nicks2k2000
Jun 15, 2008 06:14 PM
REV_29K
Mar 1, 2005 10:12 PM
