Noise from rear end
Yeah it sounds like its not coming from the suspension Jon. The only noises my car made were quiet high pitched rattling from the bearings. Which are to be expected.
As for "clunking" - sounds like it could be the CV's. There would be a distinct metal on metal sound if it was the bearings.
I thought the spacers were just for shuttering during acceleration, from when rollers (i dont know what they are called) move in and out of the existing wear grooves in the bucket. Swapping buckets side to side so that the load is applied to a "fresh" side was also supposed to fix this. Someone correct me if I'm wrong, but if you noise is over bumps and not under throttle, the spacers might not be the fix.
I found another thread that sounds like what I have here - https://www.s2ki.com/s2000/topic/819...#entry20440721. That's a great way to describe the sound, it's as if a bed headboard is hitting the wall lightly from a bed being too close to the wall. According to his technician it's the bearings, I posted to see if he had actually changed them to confirm if the technician was right.
Yeah I don't think there's any effect from accelerating or not accelerating. I know I get the sound even if I'm just cruising at constant speed around my neighborhood, since that's how I was testing it.
I have had a muted rattle from the back end since installing Penskes, using the stock mounting hardware. It occurs mostly at low speed, driving over slightly rough pavement. It is worse with more low speed compression damping. I have never figured out the source or direct cause of the noise.
I have a clunking that I figured out the other day is the OEM rear sway
I had briefly checked and tightenned the endlink nut but with one side detached I could see the play
need to get an allen key on it to properly tighten it
BTW I found the rattle was worse when cold which intuitively makes sense from an expansion/contraction point of view.
Hope this helps.
/end off topic
IntegraR0064 (Jon), how many miles are on the car and has it been launched hard (i.e. autocross or pro solo) a lot (100 or more)? This question is relative to the rear axles. I would guess that the hard launches are the biggest contributor to getting wear spots on the CV cups.
I ran my car in stock class (>250 hard launches with race tires) for a couple years before setting up for STR. Last year it was at 13" with no axle issues. This year my car is 12.5" hub center to metal fender edge and still no axle issues.
I'm really doubting the whole CV joint theory at this point because I don't get any vibration under acceleration, and the sound is completely the same if I'm on the gas or if I'm in neutral just rolling around.
Hope this helps.
/end off topic
You're talking about completely stock top hats with bushings right? how tight do you think you actually ended up going - significantly more than 40 ft lbs?
