NT01 Noob
Old Jul 16, 2013 | 08:07 AM
pgss2k's Avatar
Default NT01 Noob
Hey all
I know some of you have been running Nitto NT01's and am curious about tire pressures and the initial heat cycle. I have been running RS3's for a couple of seasons and they seem to like 39PSI hot. Are the Nitto's similar? Also the Discount tire site said they were likely to last longer/maintain the grip levels longer with a proper first heat cycle. Any insight as to what the procedure is for a proper first heat cycle with them?
Thanks
Paul
Old Jul 16, 2013 | 08:11 AM
JJ7's Avatar
JJ7
I dont run them but Im pretty sure nobody heat cycles them and they are good til they cord. They just drop off a little after a few heat cycles. I think pressures are about the same as street tires, but it depends on your set up. I run less pressure than you do with my RS3s. The generic 36-38 hot should get you close.
Old Jul 16, 2013 | 08:13 AM
pmptx's Avatar
Looking to find out, as I was an RS3 guy for track days and have run 3 days now with the NT01.
Love the grip and it keeps me competitive with the aero guys on street tires. Mechanical grip FTW.
I ran 27 cold and 35 hot on a square 255 set up and it seemed good. I will play with it next time up and down to see where the sweet spot is. I didn;t heat cycle mine, but heard the same thing. good grip til corded.
Old Jul 16, 2013 | 09:37 AM
JJ7's Avatar
JJ7
What wheel width do you run? My theory is wider wheels allow slightly lower pressures. Have you checked temps?
Old Jul 16, 2013 | 10:31 AM
pgss2k's Avatar
245 Square on 4 rear AP1 rears. -2 front camber 0 toe -2.5ish rear. Small rear toe in (can't remember specific w/o looking) GTC 200 on risers KW clubsports 10K all around Solid Gendron FSB on BB mounts. No front aero.
They are on the way so I was asking for a place to start out.
Thanks again
Old Jul 16, 2013 | 10:53 AM
JJ7's Avatar
JJ7
I was asking pmptx about his rs3s.
Old Jul 16, 2013 | 10:58 AM
ddess's Avatar
Ive used them off and in for a couple of years. I've never heat cycled them in other than driving to the track.
My target pressure has been 36-38 hot. As said above they are good till they cord. They are great first day then fall off as time goes on. I typically get 5-6 HPDE's out of a set with 4 or 5 sessions per day.
Old Jul 16, 2013 | 05:24 PM
06Estukay's Avatar
I start em off at around 31-32 psi cold. After a session, they will get up to around 37-38 psi. Like others said, the sweet spot for these tire are around 36-38 psi hot. I'm running -3.4 camber front, and -3 rear. The temperature spread across the tread is around 10 deg F hotter on inside vs. outside of tire, with center almost exactly between. Mind you, I am running 900lb springs front and 800 rear, so I'm not getting as much camber gain as a softer spring would provide. Try bumping up your front camber, if you can. Don't think -2 is sufficient for the nt01's.
Old Jul 16, 2013 | 05:28 PM
spdracerut's Avatar
I agree. I'm at -2 degrees currently on the front with NT01s and got excessive outside tire wear.
md6380
Apr 8, 2018 06:15 AM
LDubz735
Aug 2, 2016 01:17 PM
OVER 9000!
Jan 7, 2013 09:17 AM
blkblks2k
May 8, 2008 12:33 PM
Legal Bill
Apr 3, 2004 06:03 PM
