Nuetral Handling on R-compound tires
Old Nov 5, 2001 | 06:18 AM
busaboy's Avatar
Default Nuetral Handling on R-compound tires
I can finally report I got very balanced and neutral handling with G-Force R-1's. Here are the sizes:- 205/50-17 front, 235/40-17 rear, same rolling radius as stock. Comptech front (28% stiffer)and rear (10% stiffer) swaybars, but otherwise stock.
The car seemed as balanced as with the stock S-02's. I was running at Summit Point, temps between 50 to 70 degrees. They did not grip at all, and a friend running a Trans-am had the same low grip with the R-1's at Summit as I did. The trans-am changed to Hoosiers and ran 4-5 seconds faster. However, the low grip and cornering speeds gave me the confidence to push the tires and slide them aggresively. There wasn't any tendency to snap oversteer. The car was very balanced and predictable, so my guess is a "30" tire stagger works well.
Old Nov 6, 2001 | 10:09 AM
mstw's Avatar
Were you participating the NASA event on the past weekend?
Old Nov 7, 2001 | 12:10 PM
busaboy's Avatar
mstw, yes, I was at the NASA Summit event. Heading to Lime Rock on the 10th. Were you there too? I noticed Shane's yellow s2ki and a silver one.
Old Nov 7, 2001 | 01:06 PM
mstw's Avatar
I was there on the Friday before, couldn't make the NASA event and then I found out it was the last one of the year.
I'll be there next Friday for the FATT event with BSR.
glagola1
Oct 14, 2004 06:43 PM
schwett
Oct 17, 2002 10:51 AM
k_fabec
May 11, 2002 07:02 AM
StudentDriver
May 23, 2001 09:24 AM
Mark_12345
Apr 26, 2001 09:24 AM
