OEM Hartop Install
Old Dec 23, 2007 | 03:10 PM
Turn-R-Us's Avatar
Default OEM Hartop Install
I no longer have a soft top or the motor assembly and the interior is stripped. I got an OEM hardtop and realized that I can only put 2 screws in the assembly that snaps into the side strikers since the motor assembly is gone, the 2 other screws have no where to go.....
How have some of you done with this issue who are stripped.....
Thanks
Old Dec 23, 2007 | 03:44 PM
Stratocaster's Avatar
I had mounts made for both the front and rear mounts. I sold off the OEM hardware. The rear strikers sells for 300-400.
Old Dec 23, 2007 | 09:03 PM
Turn-R-Us's Avatar
One other question.....are you guys removing the black plastic/rubber strip that runs on the rear deck of the car to have the hardtop sit more flush????
Old Dec 29, 2007 | 03:18 PM
Turn-R-Us's Avatar
any input on above
Old Dec 29, 2007 | 03:40 PM
cthree's Avatar
Administrator
Get your fabricator to weld on mounting brackets. Do not remove the rubber seal.
Old Dec 29, 2007 | 03:47 PM
Turn-R-Us's Avatar
thanks
Old Dec 29, 2007 | 04:07 PM
Turn-R-Us's Avatar
One other thing....are you guys have four mount made (the same place where the OEM mounts go???
Or are you adding more mounts to the rear where the glass is??
Old Dec 29, 2007 | 05:36 PM
Ludedude's Avatar
Administrator
I don't remember a welder anywhere near your garage when we put that thing on your car back in '04
Old Dec 29, 2007 | 05:38 PM
krazik's Avatar
Administrator
I use the oem hardware, always have, 2 bolts are fine.
Old Dec 29, 2007 | 08:40 PM
What rubber seal? Can you explain?
