oil level at the track?
Old May 28, 2006 | 12:44 AM
march2000's Avatar
Default oil level at the track?
I had some issue with oil stavation on my Miata about 4 years ago, I was running about 3/4-9/10 qt. low on it at the track and with race suspension and R-Compound, I had to replaced the engine because of it. How is the S2000 engine?
Anyway, do you think S2000 can get any damage to the engine when running like 1/2 a qt. low (maybe like 2-3 x's above low line on the dipstick)? On my Miata the problem didn't show up until like a week after the yrack event (when I noticed that I was losing lots of oil, blue smoke on cold start up, etc), check the compression and it was reading almost 0 on 2 cylinders and both plug were cover in oil. After athat I always run the Miata like 1/2 a qt. to even 3/4 qt. over full mark for the track use. Anyway, I don't know much about the S2000 engine but should I overfill the oil on the S2000 for track use (like 1/2 a qts. over full) just to be sure I won't stav any oil under braking etc?
Old May 28, 2006 | 09:34 AM
boyguan's Avatar
when i go to the track i usually overfill by 1 qt.
but this is just me
Old May 28, 2006 | 01:16 PM
mikegarrison's Avatar
Safest policy is to go with the dipstick right up at the full mark. And bring a quart of oil to top it off later on in the day. Overfilling is risky, because you can aerate your oil if you overfill very much at all.
There is absolutely no reason to not at least show up with the oil level up at the full mark.
Old May 28, 2006 | 07:19 PM
krazik's Avatar
Administrator
Much at all? I've never seen any data as to how much we can over fill before we hit the crank.
I know you can put in atleast .5 qt w/o doing that.
just curious.
-Ry
Old May 28, 2006 | 08:25 PM
rlaifatt's Avatar
I usualy run at about half way on the dipstick because I find anything higher, like at full, just gets blown out the PCV valve and into the intake manifold.
Old May 28, 2006 | 11:47 PM
just curious.
-Ry
There was a post on this, I think in the UTH forum. I agree, you can overfill a little bit, but the guy who made the post claimed that when he had his engine apart he figured out where the dipstick level was, and said there was almost no tolerance between the top of the Xs and the bottom of the crank.
Regardless, I don't think anybody has ever shown a definite advantage to running above the full line. An extra half a quart really isn't going to buy you much time if you ever get into an oil starvation situation anyway.
Old May 29, 2006 | 06:34 AM
loudes13's Avatar
at .5 over I had overfill going through the pcv, at .5 qt under I spun a bearing. I will check the oil every session on my s2k for now on.
austincrx
Sep 2, 2014 11:32 AM
c32b
Jun 18, 2014 03:30 PM
wannabuy
Jun 9, 2006 03:56 AM
Cyclon36
Jun 9, 2005 08:58 AM
singlespeedman
Dec 17, 2004 08:01 AM
