Oil pressure maybe issue
Old Jan 25, 2014 | 07:15 PM
boyguan's Avatar
Default Oil pressure maybe issue
I remember before I use to have oil pressure 18 psi at idle and about 50-90 in the rpm range till vtec then it would drop to about 70 psi.
I disconnect my gauge for a bit and finally got around to hooking it up again and now I am getting 80-90 psi around 4000 rpm. I find it stranger that if rises so quickly. I let my car sit for a few weeks and wondering if it's seething wrong with the sensor
My temps are around 140-150 with outside temps about 60.
For some reason this doesn't seem too normal to me. I remember I use to see pressure at like 50-70 range more often now it's either 20 or 90
Old Jan 25, 2014 | 11:33 PM
thepoi's Avatar
From the service manual:
Oil pressure with oil temperature at 176*F, at idle: 36 psi, at 3000RPM: 85 psi.
You really shouldn't be seeing oil pressure drops below 85 above 3000RPM.
Old Jan 26, 2014 | 10:45 AM
boyguan's Avatar
I haven't seen temps get up past 150 lately with my new radiator. But lately it's pretty cool here
Think this is an issue or just because of current temps it's not dropping
Old Jan 26, 2014 | 11:19 AM
Mahjik's Avatar
Are you looking at coolant temps or oil temps (just to be sure)?
Old Jan 26, 2014 | 11:20 AM
thepoi's Avatar
The motors are designed to pretty much ride the pressure relief valve all the time, so it should basically be above 85psi all the time. I would think your earlier readings had something amiss, or you may have a legitimate oil pressure issues that the cold temps are currently masking, as you suggest. Your oil pressure should certainly not be dropping once VTEC comes on--at that high an RPM you should have a huge amount of excess pumping ability from the pump. Where is your pressure sensor? I haven't really analyzed the oil system but if you're reading pressure from somewhere in the VTEC solenoid pathway, the local pressure there may be dropping when it engages, while main pressure in the engine (bearings, head) is still well within spec.
Old Jan 26, 2014 | 01:22 PM
boyguan's Avatar
I am reading from the oil filter area with an adapter. Everyone reports a. Dip in oil pressure once vtec engages but picks up very quickly
My oil temps never go past 150 dd with 60-70 degree temp outside
Old Jan 26, 2014 | 05:38 PM
davidc1's Avatar
I use an AEM oil pressure gauge and sender. It's in a T-connector with the OE oil pressure sender. I've done this on two built NA 2.2L engines.
Honda specs state at 176degrees (warm but not hot):
idle 36psi
3000rpm 85psi
The first engine was a rebuilt one. Idle oil pressure when warm would be between 12-22psi bouncing up and down. 3000rpm would be 65-75psi, bouncing up and down.
The second engine, not rebuilt, excellent compression, is about 25-28psi at idle, and 3000rpm 75-80psi at 3000rpm, neither bouncing as much as the other engine.
It was the same exact sender and gauge for each one.
Several well respected engine builders and oil experts (including Lake Speed, Jr of Joe Gibbs Racing, who I would trust pretty much more than anyone) didn't give me any specific explanation, but told me not to worry about it.
BTW, the proper and best comparable place to read oil temps is from the pan. That's one of the reasons the new Canton pan will have 2 extra bungs there.
Old Jan 26, 2014 | 11:36 PM
boyguan's Avatar
Thx David on your input
I think my engine is fine but just weird that I can't get temps up past 150. I will be hitting the track this week and will know then
Old Jan 27, 2014 | 05:45 AM
SlowTeg's Avatar
Do you have an oil cooler or anything different than an OEM setup? Your temps sound inline with mine IF you're always moving/at highway speed. I think in <50 degree weather I got in the 130's on the highway (100% stock cooling setup). When temps are cooler out, the only time temps will climb is when I'm pushing the car (for an extended period of time), or I'm driving slow or in stop/go traffic. Then temps will hover right around water temps. If you drive the car for a bit then sit in a few minutes of stop and go traffic, you should see temps climb. If you don't, that's definitely very odd.
I'm using a plx gauge with the temp sensor in the drain plug. I'm not exactly sure WHY oil temps fall as much as they do, but I'm thinking in light load/cruising situations with plenty of airflow the OEM pan is effective at cooling the oil. On the track temps climb as you'd expect.
Old Jan 29, 2014 | 09:33 PM
sweetdill's Avatar
S2000 Racing and Competition by Speed Ventures...
Your track temps and pressures are?
