Only 4.5 degrees Caster
Due to a bent right front lower control arm I can't get more the 4.5 degrees caster. Is it worth replacing? If so, where is the best (cheapest) place to get one? It's been this way for over a year. I bent it at SOW esses. Does more caster make the car handle better on track?
Originally Posted by krazik,Sep 1 2004, 11:40 PM
It will make the car track straighter and can reduce turning effort.
More caster would increase the displacement required to turn the wheels, so I guess that means by mechanical advantage that it would reduce the force. But in a power-assisted car, I tend to notice the displacement required more than the force required.
