OTC `04 - S2KI Cup
Old 11-20-2003, 01:33 PM
Administrator
krazik's Avatar
** UPDATED ** - 01/04/04
www.opentrackchallenge.com
04 Schedule:
Monday, April 19th: Willow or Buttonwillow
Tuesday: Thunderhill
Wednesday: Sears Point (Infineon)
Thursday: California Speedway 2.5m
Friday: Arizona Motorsports Park
S2KI Cup for 04
Sponsors:
- Go Fast Lab - $500 to Prize pot
- Speed Ventures
- Additional Sponsors TBD
[ltred]OTC Registration is open.[/ltred]
http://www.opentrackchallenge.com/register.htm
[red]Signups[/red] -- Get signed up today before the OTC fills
Richard L. - rlaifatt - 2003 S2000 White
Unsigned up participants/Interest Level [red]***[/red]
Erik P. - Cthree - 10
Jason R. - JZR - 10
JP. - LudeDude - 6
Aaron H. - Strike - 6
Jason S. - Jason Saini - 5
Craig O. - SoCal Craig - 5
Doug H. - Doug Hayashi - 5
Tony P. - Payneinthe - 5 - Looking for co-driver
Prizes
- [red]$$$[/red] - Group Pot, seeded by GFL and each competitor would put in some ammt. All of pot split between top 3 finishers in cup.
** Go Fast Lab will Match $100 per entrant for the first 5 entries. **
w/ 10 entries
1st would get $900 (60%)
2nd would get $450 (30%)
3rd would get $150 (10%)
OTC Entry Cost
Current Entry costs for 04 TT U3 group is $2000 for the 5 days. +your contribution to the prize pot. $100 each.
Series Details
- We run in OTC Class U3 for overall points. But we don't follow all of the U3 rules.
---- 1 or 2 Driver per Car - Must be car owner, or 2 owner teams.
---- No towing via trailers - Cars Driven betwen tracks
-- Spec Tire: Toyo RA1
-- Spec Wheel: Stock USDM OEM 16" wheels.
-- Minimum Weight: 2900 w/ Driver (On 2 driver teams the cars official weight is the car with the lighter of the 2 drivers)
---- Allowed Mods
-- Any Shock (stock: -50lbs)
-- Any Intake, Header, Exhaust
-- Any Sway Bar
-- Any Safety Mod (Roll bar/cage, seat, harness)
-- Any brake fluid
-- Any brake lines
-- Any X-brace, STB or rear lower brace
-- Any Battery
-- Any Brake Ducting
-- no Hardtops
-- cooling mods (Thermostat, Radiator Cap, Fan switch)-- Any Clutch, PP, and Flywheel
-- Stock brake systems, rotors open to any oem "style".
-- Stock ECU only, w/o piggy backs.
-- Stock Rearend, Rear Gears open (-50lbs for stock)
-- OEM aero only, no other non-oem.
-- *** Unless specified here, all other items shall remain stock
-- *** Exceptions can be made for "cosmetic" mods. Contact rylan@gofastlab.com to get prior clearance.
Old 11-20-2003, 01:37 PM
payneinthe's Avatar
brake ducting allowed?
Sorry, due to finances, I'm very unlikely to be joining in
Old 11-20-2003, 01:40 PM
Administrator
krazik's Avatar
updated, brake ducting added.
So tony payne is a 1 wants to but not likely.
Old 11-20-2003, 01:41 PM
Strike's Avatar
Stock rearend means no gears? If so I don't even have to contemplate competing....
Old 11-20-2003, 01:43 PM
Administrator
krazik's Avatar
They aren't even in yet. don't change your gears till after OTC.
But these rules aren't fixed in stone. If everyone else doesn't mind your gears then I don't mind Just trying to keep things equal
Old 11-20-2003, 01:48 PM
Administrator
krazik's Avatar
I'd say we have till the end of december to agree on the rules. But until then we can change them.
Does anyone object to allowing any rear-gear?
payneinthe's Avatar
2 ideas to fix the gear problem:
SV-style point system
Penalty weight
Or a combination of the two
Old 11-20-2003, 01:50 PM
rlaifatt's Avatar
- Interest level at 6 at this time.
- Shocks I expect mean shock & soring (i.e. coilovers allowed)
- Any brakepad should be allowed as different makes would not affect laptimes significantly (and some like me like the endurance pads )
- Why not allow any wheels, just limit to RA1's (or RA1, PSC, and Kumho) and max size (275). I would like to use my stock wheels with street tires for the journey between tracks.
- Pulling a trailer should be allowed since not all will have access to a support vehicle.
Old 11-20-2003, 01:51 PM
vapors2k's Avatar
Penalty weight
good suggestion, I'd favor the penalty weight system over a points system. things can get debatable in terms of points.
Old 11-20-2003, 01:52 PM
Administrator
krazik's Avatar
Pulling a trailer is fine. No trailers means that you can not tow the car between tracks. If there are enuf of us we can bring an extra truck for a shared support vehicle.
I too agree that a weight system is better than a points one.
I have the scales and will be weighing each of the cars at the start of the event and probably again at some point mid week.
Quick Reply: OTC `04 - S2KI Cup
