Pedal options?
Old Sep 9, 2009 | 11:48 PM
Ben22's Avatar
Thumbs up Pedal options?
Hello all,
I am wondering if any of you have changed your pedals?
I'm looking for a wider or L-shaped accelerator to help me with my heel-toes. I find the OEM pedals a little skinny and/or not properly shaped for me. They work, but I feel like there's a better set?
I appreciate your recommendations!
Cheers,
22B
PS: still doing the "old school" heel-toe, working on the other "rolling" technique...
Old Sep 10, 2009 | 06:16 AM
Momentum's Avatar
the stock accelerator pedal have a aesthetic face riveted on, I drilled out these rivets and made a 1/8" thick aluminum face for the pedal that was about .5" wider on the side towards the brake pedal. I had the same problem when I went from wearing regular shoes to race shoes. The .5" was plenty for me but you should be able to do whatever you want for less than $10 provided you have a drill and a rivet gun (or can borrow them)... They are 1/8" rivets FYI.
Old Sep 10, 2009 | 07:12 AM
gen2gsr's Avatar
I use the RAZO gas pedal, found it for about 20 bucks. It has a left side "wing" that can be angled out closer to the brake pedal, and small spacers to bring the bottom of the pedal face closer to you. Spacers work great for matching static gas pedal height to depressed brake pedal height.
Old Sep 10, 2009 | 11:10 AM
s2kennmark's Avatar
i unbolted the gas pedal and shimmed it with washers, now it's easier to heel-toe
Old Sep 10, 2009 | 11:57 AM
marks_lude's Avatar
Care to post a pic? I would be interested in see this.
Old Sep 10, 2009 | 01:27 PM
Momentum's Avatar
sorry camera isn't at the shop pic is form an I phone and a shitty flashlight...
Old Sep 10, 2009 | 04:52 PM
crash's Avatar
I used my forearm, hammer, and pry bar to get mine closer..
probably had some shoulder and bicep action going too
Old Sep 11, 2009 | 07:00 PM
robrob's Avatar
This is from Sparco:
More info here: http://www.robrobinette.com/S2000HeelToe.htm
Old Sep 12, 2009 | 02:16 PM
ZONG9's Avatar
< www.autovationparts.com/store/hondas2000.html >
Old Sep 12, 2009 | 03:11 PM
iApex's Avatar
Does your foot ever slip off the pedal with it being just bare aluminum? You may want to put some grip tape on it to help if so. Just a suggestion.
