Possible best Hardtop for competition
Old Oct 31, 2004 | 08:34 AM
krazik's Avatar
Administrator
I've held all 3. Prolenes CF mugen, Asuras FRP and my oem and they are not that much different.
Weight wise, they are all about the same. The CF mugen is at most 10lbs lighter. Tho its a 100x prettier! (Serious, its a BEAUTIFUL peice of CF)
I weighed Prolenes at OTC 03 on Longacre Scales to be something in the mid 30lb range. I don't remember the exact figure.
Old Oct 31, 2004 | 08:37 AM
krazik's Avatar
Administrator
Originally Posted by stocky,Oct 31 2004, 09:13 AM
Only 5-8 lbs sounds strange though cause if thats the case the best way to go would be geting an OEM and replacing the rear window with plastic glass (like Macrolon)
That wouldmake it less heavy than the Mugen CF then!
Correct, out here its guestimated that an OEM w/ a lexan window would weight the same as the CF Mugen. (or within ~3-4lbs).
Don't forget tho the mugen is a better design that does have lower drag. Also if you ever cage the car, you can move the forward bars about 1-2" farther out (away from your head). Because there is more clearance.
Old Oct 31, 2004 | 08:46 AM
TriaXenginE's Avatar
I'll give you that. The mugen CF top IS indeed a work of art.
HT weight doesn't really matter to you anyway being that if there was a strong gale, your car'd be blown away.
Old Oct 31, 2004 | 09:48 AM
stocky's Avatar
So conclusion?!
Get a Mugen FRP Hardtop ?!
Good weight, les sdrag than OEM, not as expensive as Mugen CF ?!
Old Oct 31, 2004 | 09:56 AM
krazik's Avatar
Administrator
No the CF is the lightest, not the FRP. FRP is the same as oem.
Asura's Avatar
OEM and Mugen FRP are ~44lbs.
Mugen CF 34 lbs.
Drag difference btw oem and Mugen is probably equivalent to ~1/2 sec on a laptime (if that), and that is if you are good enough of a driver. For 99% of the drivers, it will not matter.
Personally, I think the Mooncraft hardtop might have some merit.
Don't forget Amuse and Seibon
Old Oct 31, 2004 | 10:17 AM
krazik's Avatar
Administrator
.5 sec?! where did you get that figure? I say no way. Maybe a 1/2nd around an oval or a track where you average like 120mph per lap.
Old Oct 31, 2004 | 10:25 AM
stocky's Avatar
I'll be running in the S2000 CUP next year on Nuerburgring Nordschleife where we also have long straights up and downhill over 120 mph.
These will be 10 weekends of 4-6 hours endurance races.
So aerodynamics will matter. Especially because I might put a small rear wing for back end downforce so the better the HT aero is the better the wing will work.
@ asura: Any info on the amuse or seibon ?!
Old Oct 31, 2004 | 10:27 AM
Seibon makes an CF top?
Old Oct 31, 2004 | 10:28 AM
krazik's Avatar
Administrator
got any more info on the s2000 cup?
Is it an enduro?
